Question about Shaw Electrical Supplies
The switch does not respond, any repair available and how can we reach you
Buy a new one via shaw cable cost 15 only.
Posted on Oct 02, 2009
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
What is diagnostic procedures for DTC p0135 & p0141
Oxygen Sensor problems... P0135 (Bank 1, Sensor 1) and P0141 (Bank 1, Sensor 2)
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it.
The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Symptoms: You will likely notice poor fuel economy the illumination of the MIL.
Causes: A code P0135 may mean that one or more of the following has happened:
O2 Heater element resistance is high
Internal short or open in the heater element
O2 heater circuit wiring high resistance
open or short to ground in the wiring harness
Possible Solutions:
Repair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141.
Symptoms: You will likely notice poor fuel economy the illumination of the Check Engine Light.
Causes: A code P0141 may mean that one or more of the following has happened:
O2 heater element resistance is high
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions:
Hope this helps (remember to rate this answer)..
May 11, 2011 | 2000 Nissan Maxima
I need wiring harness
The wiring harnesses for this system has been discontinued due to the age of the product release.
The harness may still be available from the Jensen repair facility:
PRO Tech Electronics
90 Mosswood Blvd.
Suite 500
Youngsville, NC 27596
Their telephone number is 919-562-5445, and they can also be reached by fax at 919-562-4902.
Your best bet is to call Jensen directly and order a replacement.
1. New to the Support Site :
Click here to go to the Support Account Creation Page so you can submit a support request and we can respond.
2 . Returning Customer:
Click Here to Go to the Ask A Question Page so you can submit a support request and we can respond. Note: You may have to login if you haven't already.
Apr 15, 2011 | Jensen CD-2010X CD Player
Where can I get a pressure switch 115-150 psi for a coleman 20 gallon air compressor
I do not use factory parts when possible to repair compressors. I use generic pressure switch, checkvalves, guages from www.grainger.com. Watch port size, number of access ports and unloader availability when ordering. Pressure switches are generally replaced when contacts are burned or over pressurizing to point of safety opening. If compressor is not reaching set pressure look for leaks or faulty parts in pump. Good luck
Sep 13, 2010 | Coleman Air Tools & Compressors
I have a daul stage air compesser switch which is relitivly new been in for about 3 wks an now it blows air out of the shrader valve on the switch when it reaches pressure 110 psi and kicks off it will...
The problem that you describe is caused by air leaking past the tank check valve. Easy to test/ detect faulty valve. With pressure in tank, unplug unit from power supply (for safety) and remove airline from checkvalve at tank, (usually a brass valve). Listen or test for air leak. If leaking replace with a universal in-tank check valve available from www.grainger.com. Good luck, with your repair!
Mar 19, 2010 | Square D 9013FHG14J52M1X Air Compressor...
Menu button not respondign on a Pure Bug Too
I have just heard back from Pure:
"Unfortunately the item cannot be repaired and has now been discontinued."
I have suggested, since there is no other option available to anyone in our position, that they publsih the scematics.
Sep 05, 2009 | Audio Players & Recorders
Iphone screen not responsive in certain areas
You have a broken digitizer or touch panel. Apple should give you a replacement. If you're out warranty, you can try to open it and replace the touch panel. You can get the part on Ebay or at iPhone Repair and there is a free guide that shows you how to open an iPhone and install parts at iPad Repair Guide.
Jul 20, 2009 | Apple iPhone Smartphone
Non responding windows xp explorer
download memtest86 and burn it to a cd and run report back if any error show up
Dec 10, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Repairs available?
The company Fine Digital is no longer in business in the USA. Fine Digital is a Korean company and they are one of the largest GPS manufacturers in Korea.
Nov 20, 2007 | Fine Digital FineDrive 400 GPS Receiver
Phone stopped responding after switching off for daily reboot purpose
you need to get the phones reflash with the original firmware.....you phone will be working fine after that....so take it to a repair center to get that done or go to topsony.com to do it yourself...but remember you have to pay for the firmware on that site.....but it works
Nov 03, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Electrical Supplies Logo
22 people viewed this question
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
