Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven will not turn off on older Kenmore range
My Kenmore is about 10 years old, and I have never had a problem with it until I baked cookies the other night. The oven stayed at temperature while I was baking, but when I turned it off, it stayed on and kept heating up until I actually saw flames from a few "droppings." It was as if it kicked into clean mode but it was turned off and NOT locked. I had to trip the breaker to turn it off. When I turned the breaker back on, it came on again, but when I took the oven dial off and put it back on, that seemed to reset it for some reason and it went off. I don't want to buy a new stove, but I also need to be able to trust that the oven will not suddenly come on while we are out of the house and start a fire. Any suggestions to fix this? My husband is quite handy.
  • 909 Answers
Your oven thermostat has gone faulty. You need to unplug power from the wall. Remove panel that allows access to oven thermostat, Remove knob and see what type of retaining method it has to secure it to the oven. (Does it have a nut or does it have 2 screws holding itself in position.?). How thick is the dial shaft?(5 or6 or 7 mm.thick). With that information, look now at the body of the thermostat. It should have a number sequence in the form of a sticker on it. Write it down. Phone the spares suppliers and quote them the stove model number with the other relevant items you wrote down to ensure the correct thermostat. Note, never remove wires until you are ready to transfer them one at a time from one thermostat to the other until transfer is complete. Reassemble completely and check.
Posted on Oct 01, 2009
Testimonial: "Thanks so much. You have solved the problem and I have the solution within a couple of hours of posting. Amazing!"
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a 5 year old Kitchen Aid duel fuel slide-in range. I have used clean twice since I got it. I tried to start clean today and it all went fine until I noticed after about 30 minutes that it was not...
Hi Cynthia
F5 error code normally means control board or clock failure. It means you will have to have a new control board and clock fitted.
Dec 18, 2010 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Feb 05, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
709 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
