Question about Kenmore Washing Machines
Agitator spins one way only. Older Kenmore maybe 20+ yrs.
  • 6,784 Answers
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Oct 01, 2009
I changed the dog agits in my kenmore washer but it still won't agitate
i beleive that this is the older sytle with the 4 dogs in the top half of the agitator. usually if those go the bottom half will spin - if bottom not spining maybe a transmission issue as it's directly connected to the agitator
Jul 11, 2014 | Washing Machines
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
I have Kenmore Washer Model Number 110.24812200.
It could be a couple of things. Either the basket drive block has worn or come loose and the spin tub from the basket drive is "clunking" as it skips by the notches in the block, or the basket drive spin tub has broke from the hub/base. It is likely the prior not the later.
Pull the agitator and inspect the block/hub in the center directly below the agitator which holds the basket in place. if it looks worn or is out of place, you'll likely need a tech.
If you can tackle it yourself, the block number is #389140. You want to be sure the spin tube still has the two notches in it though, otherwise the changing of the block will be futile.
Check that, and we can move forward.
Good Luck :)
Oct 29, 2009 | Kenmore Washing Machines
Kenmore 3-speed spins slowly, sounds like gears stripping. If I hold up the agitator while spin runs, it makes less gear stripping noise, but still there and still slow spin.
You probably have a bad transmission. if this machine is older, it may not be worth the value of replacement due to price of the part.
Aug 29, 2009 | Kenmore Washing Machines
Agitator does not spin.
The clutch needs replacing. The gearcase needs to be removed and the centrifugal clutch is mounted on the gearcase.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Need help fast w/ older Kenmore...
hi thanks for the question you mean liquid fabric softener in agitator if this the case if the fabric softener stayed in agitator this means it did not spin check the spin cycle to see if it spins thanks the appliance doc
Aug 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series will not agitate, spin
Check for something stuck between the basket and tub, otherwise you probably have an internal gearcase problem.
Jan 16, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
321 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
