Question about Eliminator MotoMaster Mobile Power Inverter 175 W
I need to replace the cigarette lighter plug on my 175 W mobile power inverter. Unfortunately I removed the old plug without checking the connections for polarity. reverse polarity will permanently damage the inverter. Is there a way I can confirm the polarity before connecting the replacement cigarette lighter plug? thanks, Lubo
  • 66 Answers
  • One wire is the hot and the other wire is the ground.
To find which wire is the ground wire,Take a volt meter and set it on ohms,connect one of volt meters leads to case ground,take the other volt meters lead and touch it to one on the inverters wire,when the needle or digital read out advances or makes a buzzing sound, depending on the type of meter you use,that is the ground side. Black is usually ground and red hot.center connector for lighter socket is the hot side.
Posted on Nov 20, 2009
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the...
It could be any of a number of things, but the first 2 guesses I am going to make are:
1) The contacts in the cigarette lighter jack in the tractor are corroded; or
2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
May 06, 2014 | NexxTech 175W Power Inverter
Need car adaptor for bmr100 12v to12v
As they don't make one you have 2 options.
1) Buy another Mains Adapter and Cigarette Lighter Plug, Cut the Cable & Connect to the BMR100 and connect it to the Cigarette Lighter Plug.
2) Buy a small (100W) 12V to 240V Inverter and plug your existing Mains Adapter into this. You'll get one from eBay for about £10.00 to £15.00.
May 05, 2011 | Makita BMR100 Radio
Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Jan 16, 2010 | Black & Decker PI400AB Power Inverter
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Why does the power inverter keep beeping when i plug up my laptop
If your not getting enough voltage to the inverter it will beep to let you know you don't have enough power. Most common cause is a lose connection thru your cigarette lighter. Also if you turn your key off it might be shutting down power to your plug.
Make sure you have a good connection with your battery or plug adapter. You also need a good battery so you don't go into a low voltage condition which will make your inverter beep.
Oct 29, 2009 | Black & Decker Power Inverter PI400AB
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
Cigarette Lighter broken on Ford Escape
Fuse box should be located either in the glove compartment, or to your left below stearing wheel. Also check fuses under hood, should be located next to the battery. Double check the GPS, most of them will nox plug into cigarette lighter plug. It could damage the GPS.
Jun 27, 2009 | 2006 Ford Escape
Power hook up
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Apr 22, 2009 | Black & Decker Husky 750w Power Inverter
No power to cigarette lighters
Two years later and you solved my dead cigarette lighter. manual says fuse 35--but it did not say to check 38 on the left fuse box. Thanks--blown fuse and everything works. Thanks
Dec 20, 2008 | 2007 Volkswagen Passat Sedan
Eliminator MotoMaster  Mobile Power Inverter 175 W Logo
681 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Pierre Curtis
Level 1 Expert
L Pfaff
L Pfaff
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
