Question about Sony Playstation 3 (PS3) Console
When I insert the disc it will get to the home page but will not load.
    Sniper:
  • 64 Answers
Let me guess... you have updated to latest update... right...
if no... then i dunno what it can be, if yes, then its the update and cant be solved before sony release a new update with a fix.
id normaly say that you needed to clean your lens, but after been looking on the net im pretty sure its caused by the update, and then theres no need to clean it, since it wont do any difference.
only advise i can give you is to wait for a new update, or try calling sony and see what they have to say about it, but im allmost 100% sure that they will say that you need to send your machine to them, and then they gonna "fix" it for a fee.... about 150$
Posted on Oct 01, 2009
Laptop emits continuous stream of beeps and loads advanced boot options page.
there is couple reason for that. (1) start windows normally and restore the system at previous stage. so if some driver software conflict with hardware then it solve problem. (2) insert the os disc and boot from the disc and choos repair \restore operating system. it may replace any missing system file. (3) if 1st and 2d not solve the problem then remove the RAM and clean it and fix it again. or check SMPS or Hard drive...
Jul 09, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Sony MHC-GZR888D : Error C 31 00 & tray not opening
Either its disc loading motor, or the loading belt has the fault. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Sometimes, the disc loading mechanism might need replacement. If so, contact the nearest authorised service center for Sony. The Sony disc loading mechanism can't be bought from open electronic spare part market.
May 31, 2012 | Sony MHC-881 Shelf System
Have a program to down load,when i insert disc nothing shows up o
Your disc drive then doesn't have the option for an automatic startup enabled when a disc is inserted. There are a few other ways then to make it "go." If you are using a windows operating system, click on start then on run. In the box that pops up type D: and hit enter. That will start up your disc. You can also select from the start menu, "my computer" and from that page select D: as well.
Jun 06, 2010 | Toshiba Satellite A100-S8111TD Notebook
DVD not loading/automatically playing. I've cleaned the disc and tried inserting other discs and it doesn't play/load any of them. HELP!!!!
Geek Squad at best buy could figure this out, Cd players are cheap and replacing just that part would be easy.
Feb 15, 2010 | Samsung HT-X710T Theater System
Nothing happens when I insert the recovery disc
when it tells you to take out every disc, leave the recovery disc as it contains the files needed for it to recover your system to factory specs
Jan 21, 2010 | Compaq Presario 5000 PC Desktop
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at support@microboards.com or on the web at http://www.microboards.net.
Mar 19, 2009 | Microsoft Windows XP Home Edition
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
Sony Playstation 3 (PS3) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
