Question about Kitchen Ranges
I have a DCS stove, Model # DCS-RG-304 which is approximately 10 years old, uses natural gas. Burners and broiler ignite and function properly but recently the oven does not ignite/heat. suggestions on what part could be defective and any tricks involved in replacing it.
  • skimmins Oct 01, 2009
    Thanks, it looks good. I called the DCS parts supply company and spoke to a rep who advised me after explaining the condition, advised me that he was certain it was the ignitor, "we ship these out all day long", FYI: cost $79.00
  • 6,784 Answers
HI. This will most likely be a defective or damaged ignitor. I would also advise to inspect for damaged gas valve coils as well. A damaged coil will click repeatedly. The ignitor can be inspected visually, and physically with a multimeter. Watch the burner assembly, shortly after starting the unit the ignitor should begin to glow or spark(depending on model). If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles(Glow bar). If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  • -- defective thermostat
  • -- defective selector switch
  • -- defective gas safety valve
  • -- defective gas vaklve coils
There are no tricks when installing or replacing this part. Its straight forward. There should be a kick panel in front of your unit and on the lower back side as well. Use these entry points to extract and replace if necessary.
Posted on Oct 01, 2009
  • Michael Masters
    Michael Masters Oct 01, 2009
    IGNITOR TEST PROCEDURE
    Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
Why did broiler stop working?
You have not shared where you live, and what gas you are using, but it sounds like you are either not getting the gas pressure you need, or you have sediment "dirt" plugging up your gas regulator orifice.
By any means , you need professional help, as gas problems are not for the do-it-your-selfer.
Best advice is leave stove alone until it is fixed.
God bless your efforts.
Nov 26, 2015 | Kitchen Ranges
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGST307&siteCd=WHRCOM&userType=Consumer
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
The Oven Won't Light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 08, 2010 | Dynasty DGRSC 30 Gas Kitchen Range
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Mar 24, 2010 | New World G60m Gas Single Oven
I have a 15 year old DCS 4 burner gas stove and oven. Slide in. The broiler stopped working today. Is it the broiler or the fan? How much are parts?
the likely cause is the hotsurface igniter has failed. not exactly sure how to check the part but you can check it voltage is getting to the igniter. if you have voltage, it's probably the problem.
Mar 20, 2009 | DCS CMO-24-SS Convection/Microwave Oven
DCS 304 RGA, Igniters ok. 3.9amps, no oven or broiler. No part #
Did you ever find a solution to this problem? I think my RGA 304 has the same problem, and plan to go looking for that dual valve today... Peter
Feb 21, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Broiler not working, Oven OK
We have a DCS RG-366 SS L, a 36" gas range and the igniter went out. You could smell gas and the igniter would glow red - but no fire across the broiler.
There is a place in Michigan called RepairClinic.com. We bought a replacement igniter from them and it works like a charm. It was $53 (we live close by and didn't have to have it shipped).
The item number (from the invoice) is 1191 and the box the igniter came in looks like it is manufactured by FSP, code 082005, and there is a larger number on the box that says 786324 IGNTR-OVEN.
Hope this helps.
Sep 13, 2008 | DCS RGS-305 Professional Gas Kitchen Range
Help in Replacing broiler igniter DCS RG-486GD
Jeff,
You have to remove the back of the range; the wires plug into the gas valve that controls gas to the broiler.  They detach by pulling on the slip on connector.
Aug 05, 2008 | DCS RGS-486GD Gas Kitchen Range
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Jul 30, 2007 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
157 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
