Question about Sanyo PLC XU33 Multimedia Projector
No Light from projector (worked previously)
Ready and Lamp LEDs on with power connected. Push On/Off button and fan turns on Lamp LED dims but after a few seconds hear a relay switch and Lamp LED goes back (undims). Ready LED turns off a few seconds later. Fan stays on. After a minute or so fan shuts down and both LEDs are back on. It does not matter what the system is connected to. No light is projected from the projector lamp at any time. No other LEDs are lit (Lamp Replace or Warning Temp).
  • Anonymous Mar 13, 2014
    optoma Es551
  • Anonymous Mar 16, 2014
    The projector's lamp begins to project when I turn it on and then goes off after some few seconds yet the projector remains powered on that I can hear the noise of the fan.
Theres prob something wrong wif the bulb
Posted on Dec 20, 2007
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
NO LED indicator for power, fan on, Lamp does not turn on, Lamp LED
The ballast board controls the lamp operation. Your problem lies there.
Nov 04, 2013 | Epson EMP 730 Multimedia Projector
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
Mar 20, 2009 | Eiki LC XNB4 LCD Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Sanyo PLC XU33 Multimedia Projector Logo
1,232 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
