Philips 60P8342 60 in. Rear Projection Television
Problem for Philips 60P8342 60 in. Rear Projection Television
Picture is red
By karoledesma on Oct 01, 2009
I have a 54" tv and the picture is kind of red, do I need to change something so the image looks better
Best Solution
posted on Oct 01, 2009
Very Helpful)
mark458
Rank: Master
Rating: 88%, 14 votes
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Philips 60P8342 60 in. Rear
Questions and Unsolved Problems for Philips 60P8342 60 in. Rear
Do you recommend Philips 60P8342 60 in. Rear Projection Television?
Answer
Answer
my rear projection tv is working but the picture in very light and hard to see. Almost like a glare... (More)
Answer
my 60'' Philips rear projection has a power problem. When I unplug it for awhile (weeks/months) it... (More)
Answer
Received from a friend. worked fine at their place. transported to ours and now the colors are... (More)
Answer
I have a 60P8342 projection tv. When I turn it on you can watch it for about 2hrs then it shuts... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
