How do you exchange a tsst cd rw/dvd rom for a dvd rw internally
  • For Old Hack May 11, 2010
    You: 1. Open the case, 2. Remove the screws 3. Unplug the power 4. Unplug the signal ( IDE ) cable. 5. Put in the new DVD drive 6. Screw it in. 7. Plug in the power 8. Plug in the signal cable 9. check the BIOS when you boot up to see if you are set on AUTO detection... 10. Put the OEM Burning software that came with the drive into the DVD rw, and install it. 11. Test burn a CD and a DVD. Let me know what model of CPU you have.
  • 416 Answers
Unplug all the cables from the computer to make it easier to get to it
using just screwdriver, remove the exterior cover........then locate the drive. It should be towards the top front......take a look at the IDE(flat) cable and any others that you may have plugged into there. If there are two then one is for your sound card, and the other one should be clear on the tip for power............unscrew the drive from the bay after you have disconnected the wires and cables........the drive is ready to be removed when it is laying loosely in the bay. Now push the drive to the front and it should come out from the side you put your disk in......slide the other one in and connect it back with ALL the wires and cables from before......if no place is available for the audio cable, if you had one, dont worry, it sound will still process through your sound card.
Good Luck & Please Rate This Post!!!!!
Posted on Oct 02, 2009
My samsung combo drive TSST corp CD/RW/DVD TSH492B cannot read some dvds even free from scraches but read some dvds.Bro please help me and guide how to remove this problem.
When a drive starts having this problem you need a new drive. Your drive is failing. They are very cheap online, only $20-$30 from NewEgg or Amazon.
May 01, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
My DVD-CD rom (TSST corp. DVD +-RW TS-L63H) don't function or maybe it was corrupted by virus.
The problem might be that the DVD-CD rom might be having a lens/laser problem, the lens might be weak and cannot read discs anymore. So it would not be functioning anymore. The solution to that is for you to get the laptop opened and remove the DVD-CD rom Then open the CD rom up and replace the lens.
Also the problem might be that the DVD-CD rom might have been disconnected from the inside, so all you have to do to solve that problem is for you to open the laptop up and try a new connector cable and secure the connection to the mother board is tight, then run the CD rom after reassembling the laptop together.
Take care and good luck
Oct 19, 2010 | Computers & Internet
Can I burn dvd movies with dvd r disk on my TSST corp CDW/DVD TS-H492A
You can only burn DVD's with a dvd-rw.
A CD-RW DVD will only play a dvd and write CD's
Mar 14, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
My tsst corp cd-writer/dvd-ROM combo only has cd r in recording tab how do i add a dvd-r to recording tab
angel_2001_6
In regards to adding the DVD-R tab to your burning options alot of this has to do with the burning software that you are using.
So I would like to know what program you are using and if it came with your DVD burner. Also I would like to know if you ever had the DVD-R option before.
Issken
Mar 01, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    DVD-ROM and DVD+RW
    Did you do a system "Restart" after the driver install? Sometimes that is all that is required to enable the device to work.
    Sep 11, 2009 | Intel DG31PR Motherboard
    TSST corp CDRWDVD TSH492B - DVDCD-ROM drive not working
    use this tool to reset the cd in the registry
    after you run the file - reboot the computer -
    http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
    Apr 09, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
    Computers & Internet Logo
    42 people viewed this question
    David Payne
    David Payne
