Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Can't find sat 129. Had to move dish to replace roof.
  • 56 Answers
If you area aligning your dish yourself go to point dish screen ( menu 6-1-1) then highlight satellite and choose 129, use the signal meter and dish adjustments to locate 129 by getting a green siganl bar, (note: be sure you are standing behind your dish when aligning and not in front of it)
Posted on Nov 12, 2009
My 311 receiver worked fine for years with no problems. It has always sat up on a shelf where the connecting cables wont be touched. Recently all I get out of it is a 015 message and it makes no progress...
Have you tried resetting the unit. Open the door to the activation card. Press and hold the small red button. If this does not correct it is probably the receiver. Also if the dish is near trees, new tree growth could be blocking your signal.
Sep 04, 2013 | DISH Network 311 DTV Receiver
Can urc operate dish tv top box
There is no code for satellite box with this remote control.
Jul 16, 2012 | Televison & Video
My satellite is on 129 and 119 and I want 119 and 110. I have move skew, height , and azimith with no luck. I can always get back to 129 and 119. Does the satellite default to these numbers once check...
How many coax cables are you using from your dish, 1 or 2? Do you have a switch between the dish and receivers? I am assuming your have a 1000.2 dish since you say you have the 129, 119, 110. On the LNB you have 4 coax ports. Facing the LNB, the port on the far left is for 119, the next is 110, then 129, and that last on the far right is for an additional dish. If you want to get 119 and 110, just use the 2 ports on the left. Once connected, run your check switch. I hope this helps.
Jun 27, 2011 | RCA DISH Network(r) 311 Satellite System
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
High def channels not always coming in
This problem does not have enough detail to know where to begin so I will offer a solution assuming you have Dish Network. Your dish, typically mounted on the roof of your house, has three LNBs that point to the sky. They all pick up a satellite. They are 110, 119 and 129. The latter is the HD LNB. If it is broken or tweaked and not pointing to the correctsatellite you need to get it reset. If it is loose and wobbles maybe that's why you sometimes don't get the HD channels consistently.
If you have Direct TV or a cable somebody else could help. Good luck.
Dec 28, 2009 | Televison & Video
I have a dish network 211 receiver and the 1000.2 3 lnb dish - but I can't get the switch or lnbs to detect 129W. 110 - 119 are good to go but no 129. ???
Hi! I will be more than glad to assist you in this concern. Lets check your cable connection first if all is connected hand tight on the back of the receiver, check the sat in connection. once your done, press the menu button on the remote, that is located on the upper left of the remote, once you have the main menu, press 6,1,1 on the remote on it will go to point dish, select check switch on the point dish screen, that is on the upper right of the screen, once you select check switch, it will go to the installation summary, you will see port1-119-ok-1k.2, port2-ok-1k.2 port3-con-1k.2, select test on the butom of the screen, it will run a test up to 3 or 4, it depends on the status of the lnbf, once its done, it will show the whole screen of installation summary, port1-119-ok-1k.2, port2-110-ok-1k.2, port3-129-ok-1k.2, once you see these, the problem is fix and you need to select done and it will go back to the point dish, select done, it will show you an option on the screen, then press 0, 3 times on the remote to exist all the way out, it will go to a pic or it will show attention 015, let the progress fiish and let the programming download finish as well. that will fix the problem, just incase still no 129, please unplug the power of the box from the power outlet for 1minute, plug in then you will see attention 015, press the menu button again from the remote, once you see main menu, press on the remote, 6, 1, 3, check on the field g, 119-green, 110-green, 129-green, if you got 129-green, that fix the problem, in case there is no 129, please call 1-800-333-3474, call the tech support of dish network, ask for a service call and inform them that what you did, sometimes they will ask some information, just answer the question, that is only to verify the steps that you did, If 129 sat orbital location is needed on your programming bcoz you have an hd program or your local package broadcast on 129 sat orbital location, they will setup a service call but if the sat 129 is not needed on your programming they will inform you that you dont have to worry about it. granting its needed, they will setup a service call. if you have the extended warranty plan, the service call is $29 but if you dont have, the fee is $49, the extended warranty plan is $5.99 every month. if you have any query pls feel free to get in touch..
Sep 06, 2009 | Televison & Video
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
On my 1991 SL there is a secondary hydraulic ram which is leaking badly. It is located in the roof linkage on the near side. Is it feasible to change this unit without major surgery? Where can I find...
Your softop is actuated via hydraulic rams that close latches and pull cables too move the soft top. It is a common failure. I'am assuming that it is the front latch ram's located above the windsheild.If not they are all very similar. If it is an easy one to remove or if you can see it closely-there will be a mercedes part number on the ram. it will start with a 129 prefix because your model is a 129. it will be followed by a 3 digit number and then a 4 digit. If you can read the nunber call a dealership or independent german garage and give them the number and they can order it for you. Your owner's manual should explain how operate your top manually and how to bleed your hydraulic system. I know from experience with these tops tha if you leave your key on and partially operate your roof to expose these rams it will self retract every 15 minutes so do not have your hands in the way and take your key out of the ignition because once you loose complete hydraullic pressure the roof will move. Good luck
Jun 27, 2009 | 1995 Mercedes-Benz SL-Class
Have dish receiver 510, channels i need are on transponder 21, reciever changes to transponder 4 and there is nothing!!! this is on satellite 129 only, 110 and 119 work fine
Donna,
I am sorry to hear of your troubles. I am assuming you have another receiver in the house that is an HD receiver as the 510 is not and it would not make any sense for you to have the 129 orbital without it. If you go to the other receiver and are able to get transponder 21 on the 129 bird then the issue lies in either the cabling, connectors, barrels and or wall plate, or the 510 itself. Assuming you were good to go with the hi def receiver move it to the 510 location and see if you are able to still p/u the 21 transponder. If so, the 510 is bad and needs to be replaced. If not the problem lies in the aforementioned areas. if yoou are unable to get the 21 transponder on the hi def receiver also then more than likely the dish needs to be repeaked. If I can be of more assistance let me know. Thanks for using Fix Ya.
Feb 19, 2009 | DISH Network DVR 510 DTV Receiver /...
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
555 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
