Question about Ovens
Keeping correct temperature.
We've lived in our house 15+ years, have no clue when prior owners put in this electric wall oven. The problem we're having is with the temperature, it likes to raise in the middle of baking.
  • Grandmomof7 Dec 21, 2007
    Thank you, was afraid it would be something we can't do.
    So at what point would be just need to replace this wall oven.
    Timer went berserk when we moved in here and my husband disconnected it.I do alot of cooking and baking and need dependable oven .
  • 833 Answers
It could be the 'stat. It could also be an intermittent element. With the unit off, inspect the element...they even come out with one screw. If it looks damaged, replace it. You can trick the element into seeing if it is intermittent. With the door open, start the oven. After a bit, the element should glow. It should not shut off with the door open and the temp set to 350. Do this for 10-15 minutes to test. If the element passes, see below. REMEMBER...touch nothing with the power on. There are TWO linked breakers for stoves.
About the thermostat...You don't say what type of unit you have. There are several types. Yours is probably a mechanical type which has a long metal bulb about the thickness of a pen refill which goes back to the main circuit. You can see the tube in the top of the oven area snaking out the back. If you can see it and trace it out, you can change it yourself. Make sure you have disconnected all power. Electric ovens operate on 220 volts and that can kill. Get the new unit, make sure it matches the old one. Unclamp the old one, install the new one. Tighten screws securely.
Posted on Dec 21, 2007
  • 32 Answers
You most likely need to have the oven control replaced it would be best to have someone do that for you.
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Oven is giving an F2 code and not keeping heat
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 20, 2009 | GE 30" Built-In Single Electric Wall Oven...
Wall oven not working at all
mine is broken too. exact same problem. same oven. email me if you fixed yours, please!!! quinnalisen@comcast.net
Sep 25, 2009 | Kenmore Ovens
GE Wall Oven JKP13GOTBB Touchpad is "too sensitive"??
I don't see that exact model number listed. Check the model / serial number again. If the unit is not too old, you can probably get a replacement key panel which should solve your problem.
Aug 12, 2009 | GE JTP45 Electric Double Oven
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
Kleenmaid Scala wall oven and grill
manual available at www.kleenmaid.com/care
Jan 17, 2009 | Ovens
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Kenmore electric range F5 and F3 warnings
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 13, 2008 | Kenmore 30169 Electric Single Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
