Question about Homelite Mighty Lite Lawn Trimmer
My starter pulley was broke i replaced it with a
My starter pulley was broke on my ut21506 mitylight i replaced it with a new one i had just got it started when it stoped again like all weed eaters will do after they sit for awhile, when i pulled on the string again the starter pulley broke again its the plastic piece on top of the spring...it looks like a defect to me or iam i worng ......please help !!!!
  • 279 Answers
If it was installed correctly, it is a defect. Have your supplier replace it. You may have to pay freight. Good luck...Lee
Posted on Oct 01, 2009
How do i get recoil pulley out to replace starter cord on tb6040xp
can you just wind the spool a new rope , im not that familiar with this newer equipment however some thing only change a little.
Sep 20, 2014 | Garden
2005 santa fe serpentine broke then bad vibrating and it died replaced serpentine and tensionor, now motor locked. Is the motor shot or could something else be wrong?
Put a socket and wrench on the crankshaft pulley bolt, and see if you can turn the crankshaft-clockwise. If the crank won't turn, something internal is bad. If you can turn the crankshaft normally, check that another pulley has seized.
Or try it this way: take the serpentine belt back off and see if the starter can spin the crankshaft. If it does, look for a seized pulley. If a good battery cannot make the starter turn the crankshaft, likely the motor is shot.
Aug 15, 2014 | 2005 Hyundai Santa Fe GLS
How to replace starter rope on 1993 polaris indy 500
Good luck! This model usually requires the muffler being removed,the right side of the engine disassembled.... A hint! do not remove the recoil spring unless it is broke. Turn the rope pulley clockwise about 6 times alaign the rope hole in the pulley and the starter housing , push the rope through, it helps to melt the rope ends.after the new knot is tied and pulled tight,gently release the pulley.
May 13, 2014 | Winter Sports
The idler pulley broke and shredded the belt. After replacing pulley, belt is not sitting on pulley straight. Is there some kind of part to bring pulley to where belt runs even on it?
Did you replace the idler pulley or the belt tensioner? If it was the idler pulley, make sure you transferred the insert that centers the bolt. If it was the tensioner, there is a nub that must fit into a slot on the engine block to keep it flush
Jan 12, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
2002 Volkswagen Passat power steering belt pulley broke off
find the bolts attaching the bracket to the engine (possibley2 or 3) Buy a genuine replacement assy and fit get a new belt as the old one may have suffered damage. Replace where you removed the broken bit and adjust the belt to the correct tension
Jan 11, 2013 | 2002 Volkswagen Passat
I broke th pull cord on my ryobi ss26 weed wacker.took it apart to restring is there a certain way it must go back together? does the cord through the little hole thats on the spool? if possible can i get...
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Sep 22, 2010 | Ryobi 15" Electric Factory Reconditioned...
Starter coard broke
Remove recoil assy. Turn the cord pulley in the reverse direction and hold in place, take your new cord and snake it through the holes and tie a knot on the end now put they other end through the plastic hand puller and tie a knot, Release the pulley and install.
Aug 03, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Pull cord broke on my lawn boy mower,new cord won't retract??
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 16, 2009 | Garden
The serpentine belt broke i have replaced it but the car will not start now. I was driving it when it broke. I have checked for bad wires and the battery all looks good. I have no idea where to go from...
You have charged your battery correct? If you are jump starting and the motor is not cranking then I would check the starter wires. If not please let me know and I will continue to try and help.
Jun 21, 2009 | 1993 Buick LeSabre
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from...
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Jun 16, 2009 | Mtd 22" Yard Machine Push Mower
Homelite Mighty Lite Lawn Trimmer  Logo
194 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
