The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a...
(More)
TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a barcode in a paper with this specification: single label 30 mm Width 15 mm Height every rows are made by 3 label (horizontal) with 100 mm Width 2 mm Left Margin 2 mm Right Margin 3 mm X Gap 1,5 mm Top Margin 1,5 mm Botton Margin infact 3 x 30 + 2 + 2 + 3 + 3 = 100 mm = Row width the problem is when i try to print this label the number of the feed is right but the label are completely blank for example if i try to print 9 label (= 3 row) the printer do 2 feed but nothing appear in the label i have tried to print the printer setting with this label format inside by the instruction in the manual and the info are correctly printed (for me is not a problem of paper or ribbon) i have tried to re-install the driver for Zebra Designer after downloaded it by zebra Home site the file ZD1510Certified.exe and setting the driver ''ZDesigner TLP 2844-Z'' nothing changed. what is the problem?? and the solution?? Thank you in advance for your help and assistance.
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have...
(More)
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF and the i need to take print. I need to take print directly from the application. Kindly assistance me. Regards, Ramesh ramesh.perumal@csscorp.com
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink...
(More)
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink red light am currently running windows xpsp2
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with...
(More)
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with value of 'RUBBER POLYCHLOROPRENE POLYMER' what gets printed on the label is 'RUBBER POLYCHLOROPRENE PO' Why does it print 6 spaces between the word RUBBER and the next word POLYCHLOROPRENE
