Problem on pc
When iam shut down pc this is the window i see "end program wms idle "is the message
  • yobragip Mar 05, 2009
    problem on wms idle when shuting down my computer
  • 3 Answers
Sounds like this is an issue with Microsoft Communicator. I would run the hotfix for Microsoft Office Comminicator. It s not a big one and should not take too long. The hot fix can be found at:
http://www.microsoft.com/downloads/details.aspx?familyid=A8C26743-5A77-4947-AAD4-6A6B8EF84F9C&displaylang=en
There are detailed instructions on how to laod the fix but if you have ever done an MS hotfix it is pretty standard.
Posted on Dec 21, 2007
Hi guys I have a Toshiba Laptop Model TE2300 on shut down a screen comes up saying END PROGRAM- SAMPLE this stops you shutting down what is the problem and can it be fixed thankyou Kind Regards Mark
the end programs means that some program is running while you are shutting down you have close all the program before shutting down you can just click end program or wit for the process to end by itself to know which program is running while you close press CTRL+ALT+DEl click the file you will see the program which are running go to shut down and click shut down its shut downs and the end program stops coming
Nov 14, 2010 | Toshiba Tecra TE2300 Notebook
I don't the problem exactly, but every time i shut my computer down a box come ub and its an error in closing a WMS program i hope u got the problem
it could be that your files are full, and you need to go though them to delete some..or your cookies need to be cleaned
Nov 11, 2009 | Microsoft Windows 2000 Professional for PC
Zanussi aqua pulse 6965 AL5 error
it may be the WMS is blocked, i get AL5 or AL6 at the start of the program. here is how i have fixed it the last couple of times. WMS is around £70 (in 2010) - i have that on mine every 4yrs or son - i change the WMS sometimes called the water management system or water softener. it located on the left of the machine.
the floor will get wet during this repair.
you need to turn off the power; turn off the water supply; to it take the top off remove the two screws at the back of the lid. then work your way around the left hand side removing the panel retaining screws. once that is off you can see a large blue plastic 'thing' this is the WMS that you need to replace.
to remove this you need to remove the screws around the inlet for the water, i think there are 5 or 6, some are revealed once cover plates are removed.
there are 5 or 6 retaining the WMS; the most important are the tow at the bottom toward the middle.
now gently prise off the WMS releasing the tabs and catches. do not pull it off as there are some connections still to be disconnected. As to lift the WSM at the bottom right, behind the WMS there are three pipes held on with spring clips, these need to be released. then the WMS should lift off.. replacing is the reverse of the above.
Jul 13, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Windows XP-Home Edition Shutdown problem
The MCCItrayapp is a manufactures application,
try this-
ctrl+alt+delete -> shutdown(in the menu) -> ctrl+shutdown(in menu)
This will shutdown your computer in 5 sec.
Jan 10, 2009 | Microsoft Windows XP Home Edition
PC shutsown problem
End the programs just by click on end program.
You might want to jot down which ones are giving you the problem and look them up in Google and see if it is adware or spyware in your computer causing the problem.
You can download Windows Defender from Microsoft.com for free to try to wipe it out if it is adware and/or spyware.
Jun 13, 2008 | Dell Dimension 4600 PC Desktop
Problem in shutting douwn the computer
After searching a lot on internet ,at last i have found a link for you to help you to shutdown windows when its not responding,
http://www.mydigitallife.info/2006/10/31/fast-shutdown-faster-windows-2000-windows-xp-windows-2003-and-windows-vista/
you have to make some registry changes and it's done .window will shutdown..
If this answers your question please rate this as fixed.
THANKS
May 08, 2008 | Microsoft Windows XP Professional
Windows installation
is the widows disk a original equiptment disk for your computer or is it for another computer, the program will shut the computer down after install if it dont have the right drivers,
Dec 13, 2007 | Acer Aspire L100 PC Desktop
Pc shutdown
Is there any inforation on that window or an error code. Have you install aything recetly?
Oct 20, 2007 | Computers & Internet
Photoshop 5.5 & 6.0 wont open or install
This would probably from a corrupted Installation. Try Uninstalling your product first then reboot your system. Retry installing from your installer afterwards. If this does not fix your problem let me know.
Sep 13, 2007 | Adobe Photoshop 7.0 for PC
Cant send invoices by Email
If it's the File Send To option you're using that doesn't work, that typically stops working because of a problem with WMS (Windows Messaging Services). Also, check in Internet Explorer, Tools, Internet Options, Programs and be sure the email program you're using is selected.
Mar 30, 2007 | ACCPAC Simply Accounting 2004 PRO...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
