Question about Panasonic SA-HE90 Receiver
Sa-he90 optical 3 input cant be selected
There are 3 optical inputs and 1 coax, all of which are digital. but there doesn't seem to be any way to select optical 3 which is labeled dvd. i've downloaded a manual for it and it only shows 2 optical inputs ???
please help
4 Suggested Answers
SOURCE: JVC RX-9010V - Setting up Digital Inputs
Just to the left of the volume is a "settings" button. Press it and cycle through the options until you reach "Digital Coax," then use the "Control" up and down buttons to change the assigned source.
Posted on Jul 04, 2008
SOURCE: Cant select coaxial output
Thank u very much
Posted on Dec 30, 2007
SOURCE: Panasonic SA-HE9 amp / Sky+ optical
i Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Posted on Dec 30, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    No sound on coax audio input from HDTV
    Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
    Dec 20, 2012 | Sony STR-DE835 Receiver
    Does this system have a optical input
    Here are the list of connections on this system
    • Audio inputs/outputs 2 analogue input sources,
    1 analogue output connection
    - TV : in
    - VCR : in
    - CDR : out
    - Headphone : 3.5 mm
    • Digital audio in/output : 2 digital output connection
    (coax, optical)
    • Video outputs : 3 output connections (1 S-Video)
    - TV : out
    - VCR : out
    - Monitor : out
    • Speaker Connections suitable for speakers ≥ 6 Ohm
    - left, right, center : click-fit connection
    - rear left, right : click-fit connection
    • Miscellaneous connections
    - TV center speakers pre-out : 1
    - Subwoofer pre-out : 1
    - AM antenna : loop type
    - FM antenna : coax
    please mark this fixya if it has answered your question.
    Dec 14, 2009 | Philips LX3000D System
    Input signals Marantz SR4003
    There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
    You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
    Aug 14, 2009 | Marantz SR5001
    Feb 19, 2009 | Panasonic SA-HE90 Receiver
    I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
    1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
    2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
    electech
    Nov 26, 2008 | Technics SA-TX50 Receiver
    No sound from optical or coax digital inputs
    You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
    Keith
    Oct 16, 2008 | Denon AVR-1602 Receiver
    Pioneer VSX-D608 Optical connection
    The manual states that the default association of each digital input in as follows:
    • Optical 1: CD
    • Optical 2: MD
    • Optical 3: TV
    • Coax: DVD
    Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
    As samz11 stated above, a remote is required to alter the digital input mapping.
    Sep 19, 2008 | Pioneer VSX-D608 Receiver
    Pioneer receiver VSX-D411
    Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
    Mar 21, 2008 | Pioneer VSX-D411 Receiver
    Panasonic SA-HE90 Receiver Logo
    79 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
