Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
White screen showing for a gateway FPD 1975W LCD monitor
I have a gateway monitor, model number msx6750n03721. The screen would not turn on for more than a few seconds at a time and then would shut itself off. If I unplugged it for a few min it would then do the same thing over and over again. I disasembled then reasembled monitor and now it turns on fine but all I get is a white screen. I do not get the gateway logo when monitor is turned on now either. I know that the cables and video card/ computer are working correctly. Any ideas on how to get monitor to display correctly
  • fdndp Oct 01, 2009
    Yes the screen and light(the whole monitor) would turn off completely. I would then unplug monitor from the wall and after about 1 min plug it back in and it would do the same thing of flashing on for about 1-2 sec then shut off again. Now after taking it apart the screen/monitor stays on (includeing the power light) but the screen image is completely white and doesnt change when hooked up to computer.
    thanks for the question, any ideas?
  • SvanteAssar May 11, 2010
    Would the screen turn it self off completely (Power light turns off too), or would just the screen area turn black?
Threw it in the garbage.
Posted on Oct 03, 2009
I need a driver for a FPD 1975W LCD Monitor
Please mention the serial number of your monitor or visit below page to download the driver for it.
http://support.gateway.com/support/drivers/dlcenter.asp?Tab=My
Let us know further.
Thanks for joining us.
Have a nice day.
Dec 08, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD 1975W LCD monitor,on light blinking, but wont turn on
I will assume you have already try this monitor with other PC? You should also set the PC VIDEO output resolution to be at native resolution of this monitor, which is 1440x900 @60Hz.
Mar 29, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway fpd 2485 W looked like 60 cycle lines across
Power supply will be the first thing to check, see example of failed Gateway due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
Where can you buy capacitors for my fpd 1975w monitor
They are available in electronic components stores. Use Google to search the Internet for a store near you or purchase them over the Internet.
Make sure they match the capacitance of the existing capaciyors and the voltage rating to be the same or greater.
Jun 24, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Apr 03, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
My gateway FPD 1510 is just white thats all that shows up when its connected to a computer or not. i have a gateway 2000 old monitor and id like to upgrade.
WHAT YOU WOULD SPEND TO FIX IT YOU CAN BUY LCD MONITOR 19-24 INCHS RESONIBLE CHEEP, GOODWILL OR SECOND HAND STORES 1-2 PER INCH ON SCREENS,
CANDYMANGANDY
Jan 29, 2009 | Gateway /ton 160W Power Supply (6500582)...
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway FPD 1975W - black horizontal line
Although I don't have much hope for this, it is what I would try first:
Plug the monitor into a different system to make sure the problem is not from your video card or circuit.
This will probably show the same black line since the signal received by the monitor can't really cause this kind of problem.
I'm afraid that either the LCD panel itself has a failed driver (hardware, not software) or processing prior to this is faulty.
That line is being caused by all pixels being turned on hard, producing the maximum possible black.
Most all of the components inside are placed and soldered by robots and boards are often not economically repairable.
This kind of problem is becoming more common as China takes the plowshares away from farmers and makes assembly technicians of them.
Jun 21, 2008 | Gateway FPD1975 19" LCD Monitor
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
255 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
