Thomson Projection TV
The TV Convergen is gone so I as a local technician need the circuit diagram copy so that I can fixed the problem my self. I really need your help please contact me in jaga_973214@hotmail.com OR 60163105251. The model no is SJCJ0100392
I am not sure on your model, but you will find two large IC sitting on big heatsinks - they are something like stk392-xxx or something like that. Replace them, also look for blown fuses around these ics and don't forget to look at the resistors next to the IC's.
Posted on Dec 20, 2007
I WANT CIRCUIT DIAGRAM FOR THOMSON TV CHASSIS NO.TX70 VST
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Circuit diagrams of many popular brand TVs and other devices are given
Nov 21, 2016 | Thomson Televison & Video
37PF9731D/10 Philips TV. On / off button seems to be moving "in" to the TV, making it difficult to switch on / off. I don't want to send it back to the manuf. as it will be gone for 15 days - is...
Check first the power cable.
Check the power button internally is working.
internally there is a fuse or circuit breaker, on the poower supply board near to where power cable hook up, check it out.
Tryu a different socket.
Sep 01, 2008 | Televison & Video
Retiming problem
It sounds that the convergence IC is faulty. Replace it, and check. If you wish to get more details about convergence settings to projection TVs, check the link given below. Pull up older posts there.http://electronicshelponline.blogspot.com/
May 31, 2013 | Televison & Video
Picture on screen disappears and horizontal light appears in the middle of the screen
you need to replace the vertical transistor of your tv. be careful if you want to try to fix it your self. there's high voltage inside the tv.... u need to call the technicians. the transistor won't cost you too much. it's pretty cheap. safety first. good luck
Jun 14, 2012 | Thomson Televison & Video
The color is goning out. the convergen is not working.
Go to this website.Tv Repair World.com,buy a whole a convergence for replacement.
Jan 04, 2010 | Zenith R40W46 40" Rear Projection...
The screen has gone dim
If this has happened over time, then this is not so unusual for a 5 year old projection TV. If happened suddenly then there is a problem in the video circuit. The best thing would be have a technician look att he TV. Please take a few moments to rate my answer. Thanks...
Nov 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Jul 20, 2009 | Thomson Televison & Video
Daynamic convergen
You will need to put unit in service test mode to adjust conv.. Also you will need a convergence (cross-hatch, dot and line)pattern generator for proper alignment
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
you can replace these your self if you can solder and are mechanical. there are two stk ic attached to a silver heat shield
You can call or on line give them the model number and tell them you are looking for the convergence ics The part store .com
www.partstore.com
Be careful unplug if it looks to hard please call your local tv shop the fix for a shop is around 250.00
Thanks doctor video
May 20, 2008 | Toshiba 42H81 42" Rear Projection...
Thomson tv
http://online.projectordoctor.com/Projector-TV-Lamps
http://beamerlampen.biz/projector-bulbs/projector-lamp-Thomson-44DLW617-Nr-5400.html
Dec 07, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
