Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Coiling coils do not defrost - Frigidaire FRS26H5AS Side by Side Refrigerator
  • 122 Answers
Defrost timer, and or heaters may be bad. Try finding timer near bottom back side and advance it clockwise at 1 way screw driver slot. When it clicks stop turning it and see if heaters come on. If they do replace the timer. :)
Posted on Oct 01, 2009
MODEL MFU20F3GU01 SEARL #WB80912832 UNIT WILL NOT DEFROST
Can only be tested cold and it should show resistant. or the defrost timer is not operating
Jan 25, 2016 | Refrigerators
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
REFRIGERATOR DOESN'T DEFROST. HAD SEARS AND OTHER REPAIR COMPANIES D/A SPENT ALOT IN REAPIRS AND PROBLEM STILL THE SAME.
Call complain , if paid with credit card contest payment as they did not fix problem and you paid them to do so, if paid with credit card that would also extend any repair warranty
May 04, 2015 | Samsung RF217ACRS Stainless Steel 20 Cu....
Coils ice up
My best guess is that the drain has some debris in it and the defrosted water from the coil is being picked up and being re-frozen against the coil and freezing up the drain pan. The defrost timer may have failed, the defrost termination button fastened to the coil may have failed, the defrost heater on the coil itself may have separated from the coil or just outright failed. Hope this helps and good luck.
Sep 22, 2014 | True 49 cu. ft. / 1388 liter Commercial...
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
I INSTALL A DEFROST THERMOSTAT,THAT WERE BAD THE UNIT WORK FOUR DAYS AND STARTED FREEZING UP AGAIN,BY THE WAY THERMOSTAT IS GOOD. JIMMIE
is the fan motor working in freezer ? is the defrost element getting hot to defrost coil completley ?if they are working then the defrost thermostat may not be working correctly .its connected to the coil and has 2 wires, its round, clips on the coil..good luck this t-stat shuts off the defrost element; if coil is defrosted; before the timer finishes its defrost cycle
Aug 24, 2010 | Maytag Refrigerators
Defrost brings freezer temp over 100 degrees
Unit is obviously in defrost too long. Verify defrost clock operation and time setting.You may reduce the amount of minutes per cycle that defrost is actually called on for . 20 minutes should be adequate if you are defrosting more than once per 24 hrs. Defrost clock should have "X" terminal which will terminate defrost once evaporator coils reach a certain temp. It is controlled by a three wire defrost thermostat relay(clixon) attatched to the actual coil in the event this coil reaches 50 degree,the clixon triggers the "X" wire in the timer and terminates defrosting.It figures if it reaches 50 degrees,it must then be free of ice on the coils
Jul 09, 2009 | True T-23DT Bottom Freezer Refrigerator
Icey coils,replaced bunrt defrost heater coils still ice up
Replace defrost timer and defrost thermostat.
May 13, 2009 | GE Refrigerators
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Nov 15, 2007 | GE GSS25JEMWW Side by Side
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
73 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
