Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
My light wont work in my fridge, despite changing the bulb..(twice, just to make sure). Where do I look next?
  • 80 Answers
Light switch
Posted on Oct 02, 2009
I have a 05 chevy equinox and the left brake light wont work...I changed the bulb and the light works but when i push on the brake it wont light up...any ideas of what it might be...
If you're sure the bulb is good, your next step would be to get a volt meter and test the bulb socket. You most likely have either corrosion in the socket or possibly a bad wire or ground.
Feb 23, 2015 | 2005 Chevrolet Equinox
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Samsung SR-161KTC fridge light wont work not bulb
lift the tab in center of socket , hold light switch in while doing this. or check the light switch itself.
Nov 09, 2013 | Refrigerators
I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Aug 12, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
Trying to change upper light bulb in fridge
Make sure you unplug fridge from wall power socket,remove bulb cover if one is fitted.Carefully twist or gently try to unscrew bulb. If successful take bulb to electrical parts shop and buy a new one.You may of course use your Fridge until you buy a new lamp,Refitting is simply the reverse of removing bulb.Good Luck!
Nov 23, 2011 | Refrigerators
Reverse lights do not work despite changing bulbs and checking fuse
Make sure that A) the bulb socket contacts are not flash rusted over, B) see if all the wiring is intact/ground is good, it may be the switch is gone.
Jun 16, 2010 | 1999 Dodge Caravan
Fridge light goes out
this means that your fridge light is weak already and might be time to change the bulb.
If you can do it yourself, would be good otherwise call your repairman to do it.
Jun 08, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The lights do not turn on when opening the doors despite changing the bulbs.
It sounds like the door switch. Check to see if it is sticking -- it should come out when the door is open. If it's not sticking, the switch probably needs replacing.
May 02, 2009 | Refrigerators
Light wont go on in fridge
Most often the socket is plastic and warps....One of two solutions, screw the light bulb in harder....or, unplug the unit and take a needle nosed pliers and reach inside the socket and pull lightly on the center terminal tab to make a better connection. If you need further assistance, feel free to reply...........Eric Campion
Mar 20, 2009 | GE Refrigerators
Light went out after 1 month.
We still cant get the cover off but as the fridge is only 1 month old I dont feel I should pay anything. In any case I'm not sure whether your sign means pounds, euros or dollars?
We are getting our son-in-law to come round next week and use brute force. We certainly shant buy any Whirlpool products again!
Jul 30, 2008 | Whirlpool Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
