Question about Nikon COOLPIX L18 Digital Camera
Not coming on
Camera not coming on
No flash, film does not come out
is an error rate when the camera is faulty be incorrect
Apr 11, 2014 | FUJIFILM Instax 210 Film Camera
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Camera comes on, the screen (or lens) does not.
the camera need to be serviced the lens repaired or replaced. do a google search for mike's digital camera repair. for low cost repair.
Feb 26, 2009 | Casio Exilim EX-S880 Digital Camera
High Camera Temperature Camera will shut off
That is usually the cable to the flash has come loose. Open the back of the camera and check. It is on the top left of the camera. Reseat the connector and you will be fine.
Oct 07, 2008 | Kodak EasyShare Z760 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
49 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
