Question about Lexmark X2650 All-In-One InkJet Printer
I installed new cartridges and I'm still getting a message. "cartridges replacement required" It's a Lexmark X2650 printer
  • 708 Answers
Did you put in new cartridge or refill the old? If you bought new ones you could have gotten one with a bad chip. I would take it back and exchange it for a different.
Posted on Oct 01, 2009
  • 742 Answers
It means that your printer did not detect a new cartridge installed. pull out the cartridge and turn off the printer by force by simply pulling out the plug. then after 3 minutes plug the printer back and turn ON. again it will ask for the missing cartridge. now put the cartrige in place and the printer will charge the ink.
I refilled my cartridge for x2650, its full, but doesn't print I refilled my cartridge with ink myself that i bought from Argos, now it is full of ink, but still shows the message that i must replace...
Please note that Lexmark does not recommend the use of refilled cartridges. Refilled cartridges tend to degrade in print quality and performance.
You may try to re-seat the cartridge and make sure it's properly seated in the cartridge carrier. Also note that once a cartridge is refilled, it can no longer register its ink level.
Aug 11, 2011 | Lexmark X2650 All-In-One InkJet Printer
Lexmark x2650 isnt recognising the black ink cartridge
There could be two reasons for this 1. take out the black ink cartridge make sure you have taken the plastic sticker off. 2. The contacts at the back of the cartridge might be damaged. in which case you will have to get a new ink cartridge.
Mar 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
I cannot get the cartridge carrier to move to the centre to remove the cartridge. I get alternating J and E error messages
The error indicates that the print carrier stalled. Try to unplug the printer from the power source. Open the scanner unit to access the cartridge area. Check and remove any foreign objects blocking the cartridge carrier path. Hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the cartridges then close the cover.
Replug the printer to the power source. If error still appears, please contact Lexmark technical support for additional assistance. If no error appears, reinsert your cartridges. If error reappears after installing your old cartridges, replace the cartridges with different known working cartridges or better with new set of cartridges.
I hope this information has been helpful. Thanks.
Dec 13, 2010 | Lexmark X2650 All-In-One InkJet Printer
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
My X2650 only prints pink.I an using lexmark caridges
If Inatalled new cartridge than replace and checkout another
Jul 26, 2010 | Lexmark X2650 All-In-One InkJet Printer
How to install ink cartridges #4 & 5 for 2600
Here's the User's Guide (Lexmark X2600, X2630, X2650). This should guide you on how to install/replace cartridges on your Lexmark X2600 printer. Go to Maintaining the Printer, Page 44, to view the instructions. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 22, 2010 | Lexmark X2600 InkJet Printer
Black cartrtidge is not compatible can you fix this?
Remove the incompatable cartridge and replace with a genuine Lexmark cartridge.
I know, the cartridges are expensive. They are also guaranteed to work.
Nov 02, 2009 | Lexmark X2650 All-In-One InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650 - Install of service center & compatability of ink
I regret that I just came across this. It's certainly an unusual situation. Did you contact the Lexmark Customer Support Center? Did your problem get resolved? If not, contact me directly: tlittle@lexmark.com
Mar 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
After installing ew cartridges still get cartidge low fault lexmark x2650 how do i get rid of fault
Easy! You solved the problem the way you were supposed to, just reset the printer (or load its new drivers and let them do it) to get it cleared up; or contact Lexmark about their bad cartridges. Perhaps if you'd filed this under the Lexmark x2650 you would have seen some similar problems and solutions.
Nov 26, 2008 | Computers & Internet
Lexmark X2650 All-In-One InkJet Printer Logo
209 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
