Question about Casio FX-260 Calculator
Is there a way to fix the casio fx 260 solar to display numbers in scientific notation Like 3 x 10(raised to the 2nd power)?
This can be done by setting the calculator to the right MODE. Press MODE 9 to turn on scientific notation. For example, compute 1 / 200 = and you will see 5 with a -03 exponent in the upper right. Press MODE 9 again and it will be displayed .005
To enter numbers in scientific notation use the EXP at the bottom. To enter .005, press 5 then EXP then +/- then 3. You will see it displayed. Then you can perform calculations with this entered number.
Posted on Feb 24, 2010
How to use thefunctions on the 260 fx solar
Try them by yourself or read the manual. You should be able to figure out most of them.
Aug 25, 2014 | Casio FX-260 Solar Scientific Calculator,...
How do I change from having the answers displayed in scientific notation to normal number display?
You can set your display mode to FIX or NORMAL ( 1 or 2) if you have them. However if the result is too small ( less then 0.001) or too large the calculator will use the scientific format. Generally if there are not enough display positions to show your result, the calculator uses scientific notation.
Jul 04, 2011 | Casio FX-260 Calculator
How do i take off scientic mode just a regualer:
Press SHIFT [SETUP]. You can select FIX for fixed-decimal or NORM for normal display. For FIX the calculator will prompt for the number of digits. NORM gives you two choices: 1 will display numbers of magnitude less than 10E-2 in scientific notation, 2 won't switch to scientific notation until the magnitude drops below 10E-9.
Sep 21, 2010 | Casio FX-115ES Scientific Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Apr 16, 2010 | Casio fx-300ES Calculator
How do I input a mumber in scientific notation?
The structure of a number in scientific notation is as follows
one digit [decimal mark] several digits power of 10 (- sign if needed) up to two digits for the exponent.
d.ddddd [10^] (-) dd
To enter a number in scientific notation you need to use the [EXP] key, between the [.] and the [=] sign, on the bottom row of keys.
Ex: Avogadro's number (do not worry if you do not know what it represents)
Na= 6.02 x10 ^23
6.02 [EXP] 23 [=]
Electron charge 1.6 x10 ^(-19)
1.6 [EXP] [+/-] 19 [=]
The [+/-] key is the change sign key, in the first column of keys, between the fraction key [a b/c] and the [7] key
Jan 14, 2010 | Casio FX-260 Calculator
Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Oct 01, 2009 | Casio FX-115ES Scientific Calculator
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
My casio fx-115ES is stuck in scientific notation
The FX-115ES can only handle ten digits. 14! is an eleven-digit number, thus the calculator can only display the first ten digits and a power of ten.
Feb 18, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-260 Calculator Logo
822 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
