Question about Lenovo ThinkPad X31 PC Notebook
Internal network card not appearing in hardware device list - recently the laptop was jarred
    Problem Solver:
  • 19 Answers
Run the onboad diagnostic by going into preboot set up, it's either F1 or F2 can't remember for sure, but the screen will tell you. If the device shows up there, then run a diagnostic on it. If the device doesn't show up on preboot, then there will be an errorcode stating that something is broken. 1 of 2 things have happened, the cage or thinkpad frame is bent and is shorting out the network device, or 2 the system board has been damaged. you can order replacement parts for the thinkpad, and if you're savy the board is fairly simple to replace, otherwise contact Lenovo, and they will replace the board for you, and send you a nice box to ship it in.
Thinkpad's are pretty tough, we have 5 and my X61 flew out the back of the Suburban at 25mph and it's a little bent but it still works; I use mine daily. I
Posted on Oct 01, 2009
Compaq presario v2000 wireless card not showing up in device manager
In Device Manager click the tiny arrow beside Network Adapters. This where the wireless card should be listed.
Next, locate the row of small icons just below the View tab at the top of Device Manager window.. Click the icon on the right "Scan for Hardware Changes".
Check again under Network Adapters to see if the wireless card is listed.
Or, check for any yellow exclamation marks in Device Manager list. An item might be named Unknown Device. Double-click it and select Update Driver.
Jul 01, 2014 | Compaq Presario 700 470024-192 Notebook
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
How do i turn the wireless radio on, is there a physical switch on the machine or keyboard?
The D600 has no hardware switch. Does the wireless device show up in your hardware device list? (Start/Control Panel/System/Hardware tab/Device Manager button/Network adapters). Mine shows up there as a Dell Wireless 1450 Dual band mini-PCI card. There are others that it could be. If it appears, double click on it and check it's device status. If no wireless appears there, then look for a possible unknown device under 'other'. If it is under 'other' then you need a driver.
Also, click Start/Control Panel/Network connections. You should see the wireless listed there. It could be disabled. Right click on it for options.
A lot more could be said, but try that for now.
Apr 22, 2010 | Dell Latitude D600 Notebook
Wireless card not working on my toshiba satellite a135 s4656
Is this external or internal?
A driver reinstall is a good idea. Is windows managing the device? If not switch off the other software and check that windows starts managing it.
Is the device installed at all? Check by going (using XP) click: Start> Control Panel> System> Hardware> Device manager To do so using XP click: Start> Control Panel> System> Hardware> Device manager, and find your wireless card usually under network connections.
You can get a new (likely to be faster and longer range) card on ebay for £6. might save you the worries. I did the same recently.
Hope this helps Tom,
Pople Web Design
Jan 29, 2009 | Acer Aspire 5315 Notebook
Wireless networking hardware not functioning properly.
Check on Device Manager if it is working properly
Right-click My Computer-Properties-Hardware-Device Manager
Click on the plus sign beside Network Adapter and double-click your wireless card.
Check on the device status if it says it's working properly.
Try to disable-enable the adapter by right-clicking on it under the device manager window.
If it has a question mark, it is most likely driver issues so contact your wireless card manufacturer or PC manufacturer if the wireless card is built in.
Jan 12, 2009 | Gateway MX8711 Notebook
Windows vista
hiiiiiiiiiiiiii
plz give the vista theme pack 5.5.
Oct 22, 2008 | Microsoft Windows Vista Ultimate Edition
My wireless laptop is not connecting to the internet.
  1. is there a wireless network
  2. is the wireless network open or locked down and do you have the key
  3. in windows: have you run
    ipconfig /release
    ipconfig /renew
have you looked up the network troubleshooter in the help screens
what have you altered since it did connect
Sep 20, 2008 | Computers & Internet
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
About laptop ethernet...
First figure out whether your hardware is ok and driver is installed properly. In Windows XP, click Start , right-click My Computer , and select Properties .
  1. In Windows 98 and Me, right-click My Computer , and select Properties .
  2. In Windows XP, click the Hardware tab, and then the Device Manager button. In Windows 98 and Me, click the Device Manager tab.
  3. If the Network adapters category is present with a (+) sign , then skip to Step 6. If Network Adapters has a (-) sign , continue to Step 5. Disregard adapters that do not reference an Ethernet Adapter .
  4. If a network adapter is not listed inside, do one of the following items based on the condition of the networking hardware:
    • Networking hardware is not installed. Install a new network card (desktop computer) or a new network PCMCIA card (notebook computer) per the card manufacturers' suggestions. This does not apply to on-board networking hardware.
    • The network card is not seated fully into its socket. For Desktops, remove the side-case, reseat the network card, and replace side case. For notebook computers, remove and reseat the network PCMCIA card. This does not apply to on-board networking hardware.
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play network card is probably a better option.
    • For desktop PCs with on-board networking hardware, reset the BIOS:
      1. Restart the PC.
      2. Press F1 repeatedly when the first screens appear.
      3. Press F5 and Enter to reset the BIOS to default settings.
      4. Press F10 and Enter to save the settings and exit BIOS setup .
      5. Restart the PC.
      6. Check Device Manager again for the presence of the Networks adapters category. If the network adapter name is still missing, the on-board network adapter may be damaged. The motherboard should be replaced, or a PCI network adapter should be installed.
  5. If the network adapter is listed, but has a yellow exclamation mark over its icon c00060708.jpg , do one of the following:
    • Software drivers and supportive files may be missing or corrupted. Remove the device from Device Manager and reinstall the software by restarting the computer. See Step 5: Reinstalling network adapter software drivers .
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play card is probably a better option.
  6. If the network adapter listed has a green adapter icon c00060709.jpg , the networking adapter is probably functioning correctly. If the PC still cannot connect to the Internet, make sure to complete the following steps before continuing:
    • The cable or DSL hardware may have stopped responding. Reset the cable or DSL hardware using the manufacturer suggestions.
    • There still may be a connection problem. Recheck the cable connections and replace any cables that have been pinched or that you suspect are bad.
    • The Internet Service may be down at your provider. Most Service Providers have a telephone support number. Call the ISP support number. If an outage is occurring, an automated response about system wide service outages will probably play. In this case wait until the service comes back.
    If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Thanks
Iqbal
Mar 16, 2008 | HP Pavilion ze2000 Notebook
Lenovo ThinkPad X31 PC Notebook Logo
55 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
