Question about AMD Innovatek InovaCOOL Rev4.0 Water Block for Socket A CPUs - Blue CPU Cooling Kit
Hello, just want to ask if the screen can be removed separately from unit when leaving the car? Thanks
  • 121 Answers
Do not think it can but you get other kinds, which is made to be removed, teac, and panasonic had sum
Posted on Oct 08, 2009
Hi Just trying to set up the Xbox360. Under netwok connect it is asking for "service name", what is this? I know who my service provider is, but don't know what it's asking for...
Hello Bren,
You can leave it blank, no problem!
Additional info, comes from Microsoft: "Some ISPs do not require that you enter a PPPoE server name on the PPPoE Settings screen. Contact your ISP to verify whether they require that you enter a PPPoE server name. If your ISP does not require that you enter a PPPoE server name, leave the Service Name box on the PPPoE Settings screen blank."
Aug 09, 2011 | Video Game Consoles & Games
Do we remove the wrap from the back of the unit before use
Hello Pauline,
If what your asking about is the wrap the fits side walls, top & rear of the dishwasher,leave it in place when installing in the cabinet. What it is,is a insulation/sound dampening blanket
Gene
Aug 07, 2011 | LG Dishwashers
It will not find a satellite signal
If it is a new unit it can take up to 30 minutes to find the satellite for the first time. I suggest connecting in your car and make sure it is charging and leave it on while driving to work or running errands.
If it has been working and now it is not try pressing the reset button
  • Turn the Garmin Nuvi 1300 off.
  • Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on.
  • Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds.
Once you get it going; go to the Garmin website and update the unit. Thanks for using FixYa
May 17, 2011 | Garmin nuvi 1300 Car GPS Receiver
Gas gauge always reads full.
Hello John.
The Montana/Venture vans have a problem with the fuel gauge sending units in the early 2000's.
The only cure is to drop the fuel tank, remove the sending unit and replace it.
The fuel gauge sending unit is available separately from the fuel pump.
Thank you for using FixYa.
KL
Dec 19, 2010 | 2003 Pontiac Montana
Water has got behind plastic screen, can you remove and dry the screen?
sandiboat,
Your screen is composed of three pieces. First you will have to remove the speaker grille to get to the screws that hold the screen on. Pulling gently on the side of the grille you should be able to get the grille to pop off. Move your fingers around the grille to continue removing it. Once off you should see the screws holding the screen on at the bottom of the screen. Remove all screws. If you have magic focus you will need to remove the back first so that you can disconnect the wires to the sensors. Once this is done grab the screen on both sides and lift it straight up. You may have to tug to break it loose. Once off the screen can be removed from the frame by removing all the screws around the perimeter. You should be able to separate the screens (there are three) with a razor knife and dry them. I would leave the screens apart for a few days after wiping the liquid off just to make sure there is no moisture left. Reassemble the screen as it was prior to disassembly and use duct tape or black tape around the edge to hold it together. Place it back in the bezel and reassemble the unit. It should be good and have no moisture problems.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 28, 2010 | Hitachi 51F59 51" HDTV Projection...
Removal of ac unit on 2005 trailblazer, does the radiator have to come out, thanks
It shouldnt have to be removed.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 20, 2010 | 2005 Chevrolet Trailblazer Ext
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Kenmore Model 94812 Electric laundry center
Hello handicapper,
Welcome to fixya.
You said, the above unit is new and has no separate power cord for the washer unit. Does the power come from one side of the 240 volt cord that attaches to the dryer connection?? Please advise,thank you.
Yes you are correct.
The on cord services both washer and dryer in your laundry center!
Do you have it running yet!
You should have no problem it comes with installation instructions.
If you need the user guide you can find it here online!
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0710024.pdf
If you have any more questions just ask.
Let me know that you are up and running.
Please remember to leave me the best rating.
Thank You Huuum
Oct 09, 2008 | Washing Machines
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
AMD Innovatek InovaCOOL Rev4.0 Water Block for Socket A CPUs - Blue CPU Cooling Kit Logo
162 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
