Question about Evenflo Baby Gear
Back wheel keeps coming offWheel hub keeps coming off and wheel wont stay on
  • 623 Answers
Take the stroller to a LOCAL hardware store where someone can help you find a "pushnut". This may be the part missing that holds the wheels to the axle. They come in different sizes, so you need to bring stroller.
Posted on Oct 01, 2009
2005 Kia Spectra front driver side wheel bearing making a very loud grinding sound
real easy but becareful take wd40 spray around hub and take a hammer and hit the rotor around the hub area
Sep 20, 2012 | Cars & Trucks
Changed my wheel Bearings on a g35x and now the vcd and slip light stays on and wont come off what do i do
Make sure you plugged in the ABS sensor wires into the hub alot of times you will end up changing those too when you do a wheel bearing replacement.
Sep 08, 2012 | Cars & Trucks
Wheels keep coming off
1 - Remove rear wheel
2 - Remove posi screw from bottom of rear wheel hub assembly
3 - Allow bottom block and spring to fall into palm of hand
4 - Push rear wheel lock bottom down through rear assembly to remove.
5 - Clean wheel lock button and locking plate to ensure free movement.
6 - Clean rear hub and locking button housing with dry cloth.
7 - Apply lubricant thinly in recess to allow free movement of button (dry Teflon spray is best - find it in the laundry aisle of larger supermarkets)
8 - Re-fitting is reverse procedure of removal instructions.
Nov 30, 2011 | Quinny ZAPP Stroller
1996 ford aspire wheel bearing keeps coming off is there a keeper to make it stay on
if your referring to the front hub bearing yes there should be a cotter key to keep the axle nut from backing off,but the axle nut should torqued to specifications so it doesnt back off
Jan 21, 2010 | 1997 Ford Aspire
I cannot remove rear wheels on 2005 ford focus zetec climate. I have removed all 5 nuts but the wheel wont budge
Because it has been on for a while you might need to hit hard with the wheel spanal to get it off.
Sorry
Aug 23, 2009 | 2005 Ford Focus
The AWD disabled light keeps going off & on periodiacally while I am driving and the brakes sometimes want to pump up...what is causing this ?
Rear wheel hub(s) will cause the AWD light to come on and sometimes off. After awhile that light will just stay on until you get the rear wheel hub replaced. You can either have a dealer do it for approx $500.00 or you can get the part at AutoZone for $129.00 and do it yourself. This will turn off the AWD light and also quiet the rear noise you hear.
Jul 06, 2009 | 2003 Pontiac Aztek
Front wheel slips off shaft
Pull the wheel off. Look on the back side of the wheel - you will see 4 plastic pins sticking out (inside the wheel) Use a pen to push on them - this way you will remove the hub cap without damaging it. Under the hub cap you will find the screw. You will need a torx T20 or Phillips crew driver (depending on what type of screw is there) to attach the wheel to the shaft with the screw. You can use a bit of a nail polish on the screw thread to keep from coming off again. DO NOT use glue or too much of nail polish or no one will be able to get the wheel of if needed some time in the future.
If hub cap nor the screw is there - you can find it all HERE.
Good Luck,
Rocky
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
Front wheel wont come off 1990 toyota 4 wheel drive
It appears you need to kick it off. Siezed up on the hub.
Mar 13, 2009 | 1990 Toyota Pickup
My tire studs wont stay locked in
hi if you put the studs all the way and have come loose again take one of the studs out and check to see if the locking serations in the the wheel hub are in good nick as these and the serations on the stud have to be a tight fit and be pulled right up to the wheel hub you can do this by by putting a sleeve over the stud and pull it up using the wheel nut if they seem ok try a stud locking fliud on the studs before fitting and keep an eye on them if they come loose again you will have to change the wheel hub and locking studs yates210456
Oct 01, 2008 | 1998 Pontiac Grand Prix
Baby Gear Logo
81 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Dennis Crouse
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
