Sony dvd/video slv-d980 p
HI. THE MACHINE IS DEAD, THE MANS PLUG AND INTERNAL FUSE ARE OK, HAVE HAD THIS FAULT WITH PREVIOUS MACHINES, CAPS O/C/, CAN YOU PLEASE HELP;?
  • 579 Answers
Can you post a picture of the inside and the power supply?
Posted on Dec 29, 2007
Toshiba RDXV59DT Combo recorder
Check for swollen electrolytic caps?? not a guarantee, but something I would do.
Apr 12, 2017 | Toshiba Televison & Video
We installed sensor detectors in the light switch that controlled the florescent lighting over my sewing/work area. The timer was not set properly and the outlet overheated and caused my machine to...
hi it sounds like something has shorted in the machine itself, this would defiantly be a janome repair mans job, have you checked the fuses? i think this has an internal fuse somewhere on the underside if its the same model i am thinking of, check them first, but if the socket fuse is ok, and the internal fuse is ok, then i am afraid it will be a call out hope this helps...
Jun 05, 2010 | Janome Sewing Machines
DVD wont open, Fuse is white?
its blown
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Sony SLV-D370P DVD Player/VCR
Sony SLV-D370P DVD Player / VCR Combo I get the following error -This disc cannot be played. Please check the desk DVD_ERRLOG5 00050106000000000006 01010c00000300020024 Any suggestions....
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Jul 03, 2009 | Sony SLV-D370P DVD Player/VCR
My Sony SLV-F900 VHS will not power on after power cut
If the fuse(s) check out OK, and the unit is showing no other signs of life I'd say you have a faulty switch mode power supply circuit - the best place to start is by checking all the electrolytic capacitors in it (look for any that have ruptured or are bulging on top and replace them with new caps of the same value and voltage if possible), then progress from there. Assuming the failure hasn't taken any other components out, re-capping may fix the problem but if the PSU has an IC regulator, it might be worth checking that as well. If it is shorted you may have to order a new IC which could be expensive (assuming the part is still available).
The faint sizzle would be the power transformer arcing as current passes through it. I believe there are no less than 10 caps in that circuit you need to look at. All electrolytic and all can be potential troublemakers.
You should only need to look at the caps in the power supply (replace any suspect/ruptured/leaky ones if necessary) as a starting point. If it gets too hard after that, consult a service center for a third opinion.
Dec 20, 2017 | Sony Televison & Video
Hi! I'm looking for a user manual for my newly acquired Sony SLV-2000 VCR. I've Googled and gotten nowhere. Lots of dead-ends. HELP!
Problem solved. I went online and found a pdf file for the Sony SLV-R1000 manual. This manual works just as well for the Sony SLV-2000. I'm a happy camper...
Jan 08, 2009 | Sony SVO-2000 S-VHS VCR
There's no power
Inside the machine there is a small fuse that may have blown. You need to remove the cover and replace the fuse. This is an easy fix as I had the same issue with mine.
Mar 29, 2008 | Sony SLV-D360P DVD Player/VCR
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
