Question about LG WM-1832C Front Load Washer
Code de when yo try to start load - LG WM-1832C Front Load Washer
  • 6,784 Answers
HI. This is a door open error code. check the following to address this issue.
  • Door not all the way closed
  • Loose electrical connections at door switch and pwb assembly(Check the wiring hraness that is linking the door switch mechinsm to the PWB(main control)
  • Door switch assembly is out of order
  • Gasket on door may be creased in. If creased, try to straighten, so that the door will close evenly.
((Also, try to unplug the unit for five minutes if all the above dose not clear the code. If the unit continues to display the code after the five minute reset, replace the door switch mech))
Posted on Oct 01, 2009
Lg washer de code
Try unplugging. Hold in start/pause button for 5 seconds, plug back in and see if this resets the unit.
if that doesn't work try pushing in on door while trying to start load, if hinge is issue or gasket is issue, that can cause DE err
Good luck.
Nov 05, 2016 | LG Washing Machines
Tip
Hola amigo saludos de una hispano sin duda tu post uno de los mejores explicado...
Sorry, FixYa seems to have made it impossible for the novice internet user (such as myself) to alter or edit my tips to my satisfaction so I have removed it. Sorry for any inconveniences.
Hope you will find what need elsewhere.
Macmarkus :)
on May 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Yo tengo en la lavadora el codigo f-21 what is this
F21 de error se muestra cuando la lavadora no se puede drenar, pulse Pausa / Cancelar dos veces para borrar la pantalla. Despu?s de esto, por favor revice la manguera de drenaje y filtro de la bomba de drenaje para los bloqueos y asegurarse de que no est? obstruido con part?culas extra?as. Tambi?n puede consultar la bomba de drenaje para verificar que su funcionamiento.
Si necesita m?s ayuda, consulta otros consejos en este enlace: won_39_t_finish_cycle_21_f_flashing
Esperamos que esta ayuda le sirva (recuerda votar y comentar esta respuesta).
Jul 25, 2011 | Kenmore HE2 Plus Front Load Washer
How do you recharge the vector? Don Rutledge
VECTOR VECO12B, JUMP´N CHARGE SMART BATTERY CHARGER.
Hola a todos, yo he comprado recientemente (Febrero 2011) este sistema. Yo he tenido el mismo problema el cual no carga la bater?a interna del sistema. El sistema de carga de bater?as funciona bien pero el sistema de jump-starter no funciona.
Luego de hacer varias pruebas, de leer en internet y analizar el problema, yo llegu? a la conclusi?n de que la bater?a interna esta da?ada o fuera de especificaci?n.
Que sucede? Lo que pasa es que la bater?a interna del jump-starter se encuentra en un nivel de tensi?n (Voltios) se encuentra demasiado baja, lo cual no es suficiente para que el cargador lo vea como suficiente para iniciar la carga, muestra la falla F01 o F02.
Lo que yo realice fue lo siguiente: usando el cable de carga de 12 volt DC, yo coloque un extremo conectado al salida de 12 volt DC desde jump-starter y el otro extremo del cable yo lo conect? con los cables auxiliares a una bater?a externa. Esto hace que se conecte la bater?a interna del jump-starter, con la bateria externa. Esto sin usar los cables de pinzas para bater?as.
Bajo esta condici?n yo conect? el jump-starter a una toma de 110 volts AC y yo lo encend? y luego yo seleccion? el nivel de carga (2, 4 o 6 Amps). El cargador inici? la carga de las dos baterias, (la bateria interna del jump-starter y la externa).
Esto hace que la corriente de carga se distribuya equitativamente (dependiendo de la impedancia de cada bater?a) entre las dos bater?as.
Yo lo deje en esa condici?n por 12 horas, siempre chequeando la condici?n del sistema.
Luego de ese tiempo, yo desconect? el sistema y yo medi en el socket de 12 volt DC, la bater?a interna y subi? a un nivel de 11,50 volts DC. Desde ese momento el jump-starter, comenz? a reconocer la bater?a interna como buena, y yo lo deje dos horas carg?ndose a si mismo, y luego de esto, el nivel de tensi?n era de 14,40 volts DC.
Yo apagu? el cargador y el sistema quedo cargado dispuesto para trabajar.
De todo esto yo deduzco que el problema era la bater?a interna la que no tenia suficiente nivel el?ctrico para que iniciara el cargador de baterias su trabajo.
Saludos, yo espero que esto le sea de ayuda para todos.
Ali, desde Venezuela.
alilo07@hotmail.com.
Electronic translate
VECTOR VECO12B, Jump'n CHARGE SMART BATTERY CHARGER.
Hello everyone, I recently purchased (February 2011) this system. I have had the same problem which does not charge the internal battery system. The battery charging system works fine but the jump-starter system does not work.
After various tests, online reading and analyzing the problem, I came to the conclusion that the internal battery is damaged or out of specification.
What happens? What happens is that the internal battery jump-starter is in a voltage (V) is too low, which is not enough for the charger to see it as sufficient to start charging, it displays the fault F01 or F02.
What I made was this: using the power load of 12 volt DC, I placed one end connected to 12 volt DC output from jump-starter and the other end I connected with the auxiliary cable to an external battery . This makes connecting the internal battery jump-starter, with the external battery. This without using the battery cable clamps.
Under this condition I connect the jump-starter to a power of 110 volts AC and I turned it on and then I select the level of charge (2, 4 or 6 amps). The charger begins charging the two batteries (internal battery jump-starter and external).
This makes the load current is distributed equally (depending on the impedance of each battery) between the two batteries.
I leave it in that condition for 12 hours, always checking the condition of the system.
After that time, I disconnect the system and I measurement in the 12-volt DC socket, the internal battery and up to a level of 11.50 volts DC. Since then the jump-starter, began to recognize the internal battery as well, and I leave two hours charging himself, and after that, the level of tension was of 14.40 volts DC.
I turned off the charger and the system is loaded ready for work.
From all this I deduce that the problem was the internal battery which did not have enough power level to initiate the battery charger work.
Greetings, I hope this is helpful for everyone.
Ali, from Venezuela.
Jan 30, 2011 | JUMP START SYSTEM
Necesito conseguir los drives para instalar cámara web GE modelo 98656, perdí el CD de instalación, por favor agradesco ayuda
mandame una foto de la camara con mas detalles, pues pienso que es igual a la mia, si es asi yo tengo el cd original.
Aug 23, 2010 | GE MiniCam Pro HO98656 Webcam
NECESITO UN CD ROOM DE UN QUICKLINK PEN MODELO QL 1000
MIra a este link: aqui o aqui o aqui
Yo espero que este es de ayuda.
Lo siento, pero yo no hablo mucho de espanol...
Jun 19, 2009 | Wizcom Quicklink Pen Handheld Scanner
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Yo ya intale la caja wireless-N Broadband router en my computadora Windows xP travaja vien pero a hora yo quiero intalar el internet a mi otra computadora Windows Vista co un wireless USB. mi pregunta...
Es un computador de casa o un laptop? Si es de casa entonces deves de instalar el USB Adapter en la connecion mas alta para poder agarar el signal mas potente. No importa si es adelante o atras
Antes de instalar el USB adapter devs de instalar los Drivers del USB adapter antes.
Dec 01, 2008 | Computers & Internet
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
MSTR2KX
ve al home page, de esta pagina y en el lado izquierdo inferior busca services, y pon tu zip code o codigo postal, y ahi encontraras los lugares de autoglass disponibles en tu area
Jun 20, 2008 | 1992 Chevrolet Camaro
LG WM-1832C Front Load Washer Logo
134 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
