How do I change the print size on a HP Laser Jet Plus?
If you are in a word document go to format and click on font.
Posted on Oct 01, 2009
HP Laser Jet 4 Plus + PC Load Legal
PC Load Legal means that the printer has been sent a print job formatted for legal size paper and that is not what is currently loaded into the printer's input tray. So, either change the paper to legal or cancel the job in the printer, reconfigure the document on the computer for letter (or whatever is loaded into your printer), and send the job again.
Jan 22, 2013 | HP LaserJet 4 plus Printer
Hp laser jet 4 plus prints only half the page then black pages then the other half with cryptic writing on pages over text
What I would do, is go out the www.hp.com/#support.
Download the latest drivers.
Install them and start printing again.
If it fails again, print a config page. If that prints correctly, that tells you that the printer is working correctly. Problem is with the interface. If you are using the parallel interface, try a different cable.
If you are using the jet direct try a different one and a different cable.
Could also be a bad formatter.
Good luck
Feb 18, 2011 | HP LaserJet 4 plus Printer
We want to purches a laser printer for printinhg legal size paper,which printer we use
Hello
You can any of HP laser Jet with your budget for legal size printing, all printer can print legal size printing, however there are some printers for quick reference.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
Dec 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have streaks on my print outs from hp laser jet
check your toner cartridge, check your fuser rollers and check your transfer roller assembly.
Sep 23, 2009 | HP LaserJet 4 plus Printer
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Aug 17, 2008 | Emulex NetJet (NJ01B-NTplus) Print Server
Hp Laser jet 4 plus
Bad toner cartridge or fuser is burned out.
Aug 15, 2008 | HP LaserJet 4 plus Printer
HP Laser Jer 4 M plus
How is the machine connected? try changing the data cable if this doesn't work then shutdown your computer while the machine is on and reboot as if it is connected via LPT port some systems like to have the printer on before the computer.
Try this and I hope it helps if it doesn't then you might have a faulty print formatter board.
Thanks J
Nov 20, 2007 | HP LaserJet 4 plus Printer
Hp laser jet 4 plus printer
Need some additional info: -Network based or connected direct to the workstation? -How big are the pdf files? -Has anything changed with the printer, workstation/server host?
Dec 03, 2006 | HP LaserJet 4 plus Printer
27 people viewed this question
jasbo
jasbo
