Question about Panasonic NN-T774SF Microwave Oven
Cooking temps I'm trying to use a recipe that was made in a 600watt microwave and my microwave is a model NN-T785SF which is a 1250W-what power level should I use?
  • 833 Answers
I'd try 50-60%.
Posted on Dec 20, 2007
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
Start button not working
take it to a repair shop many things can cause this problem
May 11, 2015 | Panasonic NN-H765WF Microwave Oven, 1.6...
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Panasonic NN-T785SF microwave smoking and popping
Not to worry ,Please use a good torch light or lamp to look inside the microwave cabin. On the side where the magnetron is fixed look for any food particles which could have stuck while heating. Use a good cleaning solvent to do this job. You must remove all the roller and plates and clean dry. Once you have done this open the top cabinet with the mains wires disconnected. Look inside the side panels for dirt, insect which have got entangled and cooked. use a good brush and blower to clean dry. If the main capacitor has leaked replace with a similar type. Get help if you are not able to do this as it is a dangeorus section with high voltage. You will get to the smelling part once you had inspected these areas. Replace the part in question, can be even the surge protector at the mains end. Hope this helps. Good day
Jul 19, 2010 | Panasonic Microwave Ovens
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Panasonic NN-T774SF Microwave Oven Logo
128 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
