Question about Aprilaire 600 Humidifier
It does not stay running, even if I switch it to "on". It seems to come on if I switch it back and forth but it doesn't stay running
  • Aprilaire Expert
  • 252 Answers
The on setting is actually a test setting. the humidistat with the aprilaire does not have an on setting you can only set it just below test which would be it's highest setting
Posted on Oct 03, 2009
Fan won't run. New filter and wick. Why won't the fan come on?
work switch back and forth a few times . sometimes they seem to gum up over summer
Feb 06, 2015 | Humidifiers
INSTALLED HE360A, FAN MOTOR RUNS, EVEN WHEN FURNACE IS OFF? IS THIS NORMAL
Yes - but it doesn't have to work that way. There are several methods you can use to have the humidifier run only when the furnace runs. Look on the back page of the installation instructions. The method I chose was to install a sail switch. This is a switch with a arm attached which has a "sail' attached to it. When the furnace blower runs, the sail catches the blower airflow and activates the switch; allowing the humidifier to operate.
You can also wire in a current sensing relay (figure 6 on the instructions) or connect the humidifier directly into the furnace motor ignition box (if so equipped. My furnace dates to the late 70's and has no place to plug in a humidifier; which is why I installed a sail switch.)
Now however I probably would go with the current sensing relay option as this looks to be the easiest route to follow. Honeywell has their 32001754-001 avaliable for less than $35 from Sears.
Dec 01, 2010 | Honeywell HE360A1027 Whole House...
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Humdifier wont work
I'm having the same issue
Jan 18, 2009 | Honeywell HWM-260 Humidifier
Fan shuts off too soon after oil burner stops
That is an old style t-stat i would replace it with a more up to date model. Your problem may be in the limit switch. But yes to answer your question most fans can be adjusted just depends on if it has a manual limit that looks like a silver box on the interior of your furnace or if it has a mother board control system.
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Thermostat Will NOT Turn OFF
Most of these have a flag switch which starts then when the duct air goes through. If that fan switch is stuck it wil not turn off.
Dec 28, 2008 | Honeywell Power Humidifier: Furnace...
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
233 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
