Question about Makita Usa Inc 9557PB 4 1/2" Angle Grinder
I don't know how to change the grinding blade on my makita angle grinder.
  • Anonymous Mar 22, 2014
    How to change blade on 7750 b&d angle grinder
  • 5,660 Answers
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Posted on Oct 01, 2009
  • joecoolvette
    joecoolvette Oct 02, 2009
    Error:
    "On on each side of the U shape", should be "One on each side of the U shape"
  • joecoolvette
    joecoolvette Oct 03, 2009
    Additional error, my apologizes!
    As you view the grinding wheel facing you, the locknut is turned towards the RIGHT to loosen.
    Again my apologizes for this erroneous statement.
  • 557 Answers
Lock the shart and spin the blade counter clockwise.
2 Suggested Answers
housejess
  • 317 Answers
SOURCE: angle grinder
on a grinder the nut that holds the wheel on has left handed threads.....that means it has to be turned in the opposite direction than conventional nuts do..there should be a button on the casing to hold in..this keeps the grinding wheel from turning wheel being removed....remember to unplug first..thanks and have a great day
Posted on Jan 03, 2010
How do you get to the inside of a makita 4.5"
there is a screw in the bottom of grinder next to the power cord, that's all you have to take.
(althought I don't know the model of your grinder, the most of makita brands have the screw right there) good luck!
Jul 02, 2011 | Makita Saws
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
My makita grinder was working just fine wile I was grinding it just quit on me and now it will not even start
You can try removing brush covers and brushes to check and clean as needed.I have a makita grinder and have to change brushes about every two years but I use mine a lot in very dusty conditions.I think that I would probably check on/off switch about first as I have had mine do exactly what you have and I replaced the switch and it's still working.I have had mine for 15 years.Great little grinders. If you feel comfortable doing so you can bypass swith to make sure motor is good. Best of luck and thank you.
Apr 17, 2011 | Makita Angle Grinder 4.5" 9524NBX
How do I remove the disk from a Makita 9009B 230mm Angle Grinder
The locking nut undoes in the same direction as the blade spins. It's done now!
Thanks
Apr 02, 2011 | Makita Angle Grinder
I have a Makita 100mm Disc grinder what attachments are available for this older tool...model M952
as its a grinder...there are not many attachments available....just your common grinding and cutting discs.
Aug 06, 2010 | Makita 9553NB 4" Angle Grinder
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
Breaks support rings in all blades
are you using the proper inner blade flange?? that is the only thing that I can think of that would cause your problem
Jun 12, 2010 | Makita 9553NB 4" Angle Grinder
I got a Makita4
Your missing the flat wrench that goes under the blade and holds the shaft from turning. I can't find anywhere to buy just the wrench. If you can find an old 14mm wrench and grind it down on both sides so that it's only about 1/8 of an inch thick it should work.
Jan 08, 2010 | Makita 9553NB 4" Angle Grinder
Angle grinder
Jan 03, 2010 | Saws
How to change a cutting disc.
You can download a manual for a 9" unit (9069S) from
http://www.materielsektionen.dk/skabelon/pdf/359.pdf
I know it's a Danish site, but the manual itself is multi-lingual and includes English.
Dec 03, 2008 | Makita 9069 9" Angle Grinder
Makita Usa Inc 9557PB 4 1/2" Angle Grinder Logo
2,395 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
