My honeywell t8600c1212 displays the time and -AC. It is not functioning (no heat or air conditioning). I replaced the AAA batteries. Any suggestions?
  • 252 Answers
-AC means it's not getting power from the furnace. the problem is at the furnace not the thermostat
Posted on Oct 03, 2009
Testimonial: "It's now working. The problem was indeed in the power supply, not the thermostat. Thanks so much for your help."
I just finished changing the 3 AAA batteries and now the themostat does not work so... how do reset my honeywell digital thermostat? to get it to work again
Found this for you:
Insert the batteries backward, so that the negative pole lines up with the positive terminal. Leave the batteries placed backward for at least five seconds.
Remove the batteries and put them back in the correct way, then close the battery door. The display will turn on. The thermostat is now reset
May 17, 2017 | Honeywell Heating & Cooling
Could you please give me the code for a Lennox HG31ES air conditioner? I have just bought a universal remote and haven't got the code. Regards Lynda
I doubt a 'universal remote control' will work for air conditioning. They are for televisions and DVD players.
If it is one of these, it should work out of the box.
Over 2000 CODES, OPERATES ALL LENNOX MODELS.
Full function universal remote control for all brands of air conditioners.
Large electric blue LCD backlight display. A product to satisfy all exigencies, with an attractive design and a full range of original brands covered.
Extremely easy to program with auto-search feature.
With over 2000 codes in the memory it makes this product the most complete on the market.
The big display with Backlight and clarity of indication of the functions complete the huge success of this product.
User manual included.
Supplied with wall mount bracket.
Remote control is gold in colour.
*Requires 2X AAA Batteries.
REPLACEMENT UNIVERSAL LENNOX AC AIR CONDITIONER REMOTE CONTROL FULL...
Or you could ask Lennox direct?
http://www.lennox.com/help
Dec 06, 2016 | Heating & Cooling
My Honeywell Themostat is no longer controlling the systems after a battery change, but otherwise looks fine. Help!
The replacement batteries could be defective or installed incorrectly. Also, if the thermostat has to be removed from its mounting base for installation of replacement batteries, it may have been reinstalled incorrectly.
Nov 07, 2015 | Honeywell Heat/Cool Thermostat
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
The display went blank on my honeywell t8600c thermostat. when the batteries were changed, the display shows the time and -AC. Nothing else functions
I believe this thermostat will display -ac if it loses power from the furnace or air handler. Your thermostat will operate on low voltage(same as your door bell) and constantly powers your thermostat. I would check your furnace breaker, and fuses to see if there is power to the equipment
Nov 03, 2013 | Heating & Cooling
Touchscreen is not functioning
First try replacing the batteries. I have a slightly diff honeywell model and it takes 2 "AAA" batteries. The battery holder comes out the side of the unit, just press where it says press and pull out.
Sep 11, 2012 | Honeywell Rth8500d 7-day Touchscreen...
Honeywell DT200 thermostat is not responding to any buttons pressed. Display is showing small flame icon on left of screen and what looks like a battery in top right hand corner. Any suggestions?
The thermostat is calling for heat, and the battery icon means that the batteries are low and should be replaced. If the thermostat is wired to run on battery power alone, replacing the batteries usually corrects this problem. Hope this helps! Jim
Jan 29, 2011 | Honeywell Heating & Cooling
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Sep 24, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
