Question about Canon PIXMA iP3300 InkJet Photo Printer
How do i put the printer inks in to the printer? do i remove the orange tabs etc?
    President:
  • 1,653 Answers
Download the following document from Canon Support
http://files.canon-europe.com/files/soft33412/manual/iP3600%20series%20(EN).pdf
and refer to page 44 onwards for illustrated instructions.
Posted on Oct 01, 2009
How do I a new install an ink cartridge?
No, you do not remove the orange device. there should be tabs on the front of that to push or pull. that will unseat the cartridge and you can then remove it by hand and replace.
Feb 21, 2015 | HP 564 XL Series Ink Cartridge Set for...
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Apr 17, 2012 | Canon Office Equipment & Supplies
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Need to know how to change printer ink
Do not touch the electrical contacts or print head nozzles on the Cartridge. The machine may not print properly if you touch it.
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (C).
genebur2_1.jpg 3. Pinch the tabs and open the Ink Cartridge Locking Cover.
4. Remove the Cartridge.
genebur2_2.jpg 5. Take a new Cartridge out of its package and remove the orange protective tape gently
6. Put a new Cartridge in the Cartridge Holder.(The Color Cartridge should be installed into the left slot and the Black Cartridge should be into the right slot.)
7. Close the Ink Cartridge Locking Cover to lock the Cartridge into place.
8. Push down the Ink Cartridge Locking Cover until it clicks.
Nov 08, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How to replace ink
Hi Good day!!!
to change your ink cartridges follow this steps
1. Switch on your printer by pressing the power button.
2. Open the cartridge access door and wait for the cartridge carrier to move to the middle.
3. Press the tab in front of the empty ink cartridge and remove it from the slot.
4. Remove the plastic wrapping from the replacement ink cartridge and take off the orange tab. To do this, carefully twist the tab and snap it off.
5. Place the new cartridge into the slot you removed the old cartridge from; then push it down until it clicks into place. The label must be on top of the cartridge, and the plastic tab should be at the back.
6. Close the cartridge access door, and your ink cartridge will be ready for use.
Don't forget to vote thanks!!!
Nov 02, 2010 | HP Officejet 4355 All-In-One InkJet...
How do you remove the ink cartridges from the
To service the ink tanks:
Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
i_note_us.gif Note
If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2 Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3 Remove the ink tank whose lamp is flashing fast.
(1) Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Important
bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
i_note_us.gif Note
Be sure to replace ink tanks one by one when replacing more than one ink tank.
4 Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
(1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
(2) Remove the orange protective cap from the bottom of the ink tank and discard it.
Important
bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
bullet_s.gif Do not re-attach the protective cap once you have removed it.
bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5 Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important
Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6 Close the Inner Cover.
i_note_us.gif Note
Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7 Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
i_note_us.gif Note
bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
How do I change the ink cartridges's?
Confirm that the printer power in on, and that the machine is idle (not busy printing).
Have the new ink tank handy. You need to complete the installation within 10 minutes (however, you can start again).
1) Open the top cover - the printhead moves to the replacement position
2) Remove the tank to be replaced by pushing in gently on the front tab and lifting up, then out on the tank to be removed
3) Make sure you have the correct replacement ink tank. Tear the orange strip completely from the new ink tank and remove the packaging film
4) Remove the orange plastic protector cap
5) Insert the new ink tank in the correct slot and push in and down until it clicks into place.
6) Close the top cover
7) The next time the printer starts, it may initiate a procedure for preparing the (any) new cartridge(s). Let it complete this procedure before sending a print job.
I hope this info was helpful!
Mar 02, 2010 | Canon PIXMA iP3500 Printer
Cant instal this ink cartridge
This pull tab is on the cartridge to prevent it from leaking during shipment. You have to remove it to let the toner get to the drum.
Mar 06, 2009 | HP LaserJet 1500 Printer
On/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 22, 2008 | Canon BubbleJet i320 Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
69 people viewed this question
old marine
old marine
