Question about Dryers
LG Tromm dryer now takes two cycles to dry a load
This just started happening last week. The dryer is taking longer to dry clothes. This is the LG TROMM DLG5988w. The lint is cleared from the trap regularly. Any advice would be appreciated.
Thank you,
Rob
  • 4 more comments
  • robdogule Dec 20, 2007
    Also note that the metal piece on the inside of the cylinder is heating up.
  • robdogule Dec 24, 2007
    Hi Bob,
    Thanks for your helpful ideas. I will try resetting the breaker. I'm not sure what you mean by air outlet, but assuming you talking about the air vent. I went ahead and pulled off the vent temporarily and vacummed inside the machine to get any additional lint. I going to see if I can run a load without it connected to rule it out. Also as you mentioned the thermostat my be off. I'm not sure what to do with it and am aware of the electrical hazard so I might stop there.
  • robdogule Apr 28, 2008
    Thank you Bob and Guest. Six months later the dryer is still working. It turned out to be lint in the back of the machine where the exhaust pipe is connected. I pulled off the pipe and vacuumed it out. I think the best hint was the lack of drying gradually got worse over a span of a week. It did not start until I inserted one of those foil coils (vs aluminum or tin) which I have been told that they can cause cloggages quicker. I'm not sure if this is true because I left this on and ever since there has not been a problem. Possibly there was a kink in it. Who knows.
    Did I say 6 months, I meant 5. Thanks again
  • iluvskunks Jun 16, 2008
    My LG Tromm gas dryer is not heating. It's never really dried the clothes all the way anyway. We'd have to put everything on the highest heat setting and clothes would mostly dry but not completely. However, now we have no heat at all. I've cleaned out the lint section and also disconnected the exhaust pipe to see if heat comes out while it's running. No heat! Any suggestions?
  • candyhannah1 Mar 27, 2009
    I have not heat at all just cold air. It was never the best at heating but now none at all. Only 2 years old
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Posted on Apr 28, 2010
  • lilmonsters3 Oct 01, 2010
    We have had issues on and off with our LG Tromm Washer and Dryer. However, each issue was easily fixed by ourselves. Yes the dryer does let a lot of lint get through, and we now have to clean out the drain filter of our washer. However, with front loaders comes a deal of responsibility in taking care of them. I hated my top loader washer with a passion. Our water bills were outrageous and with 3 kids in sports, school and working on our acre of mountain property these have really saved us. I guess what I would have to say for all the people with problems is that, you will have to do some maintenance work yourself to keep these working in tip top shape.
    If you have an OE error on your washer, go to the bottom left side of the washer to the little door. Open the valve (when you the washer is empty or you'll get a lot of water) clean that trap out and your ready to go. Silt will build up. Also, if you experience water leakage that's your main culprit..
    Dryer, make sure that you take apart the lint trap inside and clean that out with a vacuum. Also clean the lint out from behind the machine too. Take off the duct and vacuum inside the dryer. These are high efficiency machine. You will only have to do this a few times a year. Or you can have a technician come out and do it for you. That would be the very first things they do to check if there is any mechanical error or just blocked ducts.
    I would take the time to do it yourself. Technology isn't perfect, I guess we'll all have to understand that. But I would take these few simple steps over a high priced water and energy bill any day.
  • 833 Answers
First, check that you are getting 220 volts to the unit. Some will partly work on 110. Turn BOTH breakers off and back on. Check all connections from breakers to unit. Is the air outlet jammed? Then, look at the thermostat. Has the washer spun the clothes as dry as before?
Posted on Dec 21, 2007
Rob, sounds like you're on the right track. The other things that could be bad is part of the heater coil is out or, less likely, that you have thermostat or high limit switch issues. These will likely require a service person to resolve. Good luck, sir.
Posted on Dec 24, 2007
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 17, 2010 | LG DLG7188 Gas Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
My LG Tromm dryer is taking two cycles to dry clothes. They are just not drying completely with one cycle.
make sure that the vent system is clear all the way to the outside. I've seen bird nest in these vents as well as just plain lint build up.
You should feel alot of air coming out when the dryer is running.
May 15, 2009 | LG DLE2514 Electric Dryer
Dryers Logo
10,724 people viewed this question
Top Dryers Experts
Marvin
Marvin
