Question about AOpen AX45F-4DN Motherboard
The fan on my motherboard is not running when power is on
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi, Are you able to boot the machine into windows without the fan running?
Should rear fan run all of the time or only when needed?
Depending on if the fan is plugged into only a molex (power) connector, or into a fan port on your motherboard, it could go either way. If it's plugged into the motherboard, there's a good chance the motherboard is controlling it thermostatically. A case fan venting out is always a great way to help improve airflow and keep components cool.
Hope this helps!
Sep 16, 2014 | Systemax Tiger (SYXS-DC-1000) PC Desktop
P5p800vm no power
Your PSU would seem to have failed.
Aug 15, 2013 | PC Chips Computers & Internet
Fan failure from the start..power failure
open your cpu check whether your fan running or not, if it run mean , go to bios and disable the alert so that you can log in to your OS.
If fan not run mean
Open up the case, check the CPU heatsink fan is connected to the motherboard, if it is try booting up with the side panel still off, does the fan spin up?
Check it, good luck
Jan 11, 2011 | ASUS P4S800 Motherboard
No lights no power no fan
Please check if all the power cables are plugged in properly and check whether the fan in power supply is running after powering the system.
1. If the power supply fan is running then remove the memory( RAM) installed in your system, try changing the slot and if the issue still persists then the issue is with the motherboard and then you would need to check with the local technician.
2. In case the power supply fan is not running then removed the main power connector (the biggest one coming out from the power supply and going into the mother board) from the mother board. Check if the power supply fan runs or not, if it does then perform 'step 1' and if it doesn't then replace the power supply.
Regards
Anand Sachan
Nov 02, 2010 | Dell (1K529) Motherboard
Power supply is good, fans running - no display on
make sure to check the video cable (DVI,VGA,HDMI) if properly connected
if youre using an independent video card and your motherboard has a builtin try to use the integrated to check if the video card is faulty
if you dont have a video card and using the integrated the motherboard might be faulty
Jul 20, 2010 | Asrock P4I45GV R5 Motherboard
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
http://dlcdnas.asus.com/pub/ASUS/mb/socka/sis741GX/e1766_a7s8x-mx.pdf
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
How i turn off a fan from motherboard
The fans that are plugged into the motherboard are usually powered by the motherboard. To turn them off, simply unplug them as there is always a power flow going through the motherboard and even more to power the fans when the system is running. I would recommend keeping the fan in if possible to help with cooling your PowerEdge 1400 server, but if it must be removed, simply power your server down, and unplug the fan. Make sure your server is powered off before doing this, as you don't want to short anything out or cause a spark.
Mar 13, 2009 | Dell PowerEdge 1400...
Problems with Gigabyte GA-8I845GVM-RZ Motherboard
nothing but the fans run.the hard drive will run if i unplug the ribon.I changed the power supply and still not working
Mar 08, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Power supply
fan o. k
get the eq wit a bootable win. disc and run into the bios for a new set in xp
Oct 15, 2007 | Gateway (4000484) Motherboard
AOpen AX45F-4DN Motherboard Logo
66 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
