Question about ASUS K8N-E Motherboard
System not booting, k8n
After shutting down the system in the normal way it won't boot up anymore.
All fans spin and led on motherboard lights up, no beeps also reset button not working and the case power led not working.
Both cd and dvd lights stay on and drawers won't open unless i disconnect the ribbon from the motherboard, and hard drives don't spin up unless i disconnect ribbon from the motherboard.
i have tried booting without graphics card, memory, cd & dvd and hard drives connected but still no beeps
    Scholar:
  • 138 Answers
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Posted on Oct 04, 2009
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
Mar 26, 2012 | Computers & Internet
Every time there is a problem of overheating error and my system shuts down .when i restart my computer cpu produce beeps . motherboard is of Intel 915 series is used.......
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is the problemis not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Sep 09, 2011 | Intel D915GLVG Motherboard
I've got an Acer Travelmate 292LMI. My problem is: the notebook starts (leds on) for only a few seconds (I can see the acer display that preceeds the boot) but immediately it is dead. Only the AC leds...
It could be an overheating CPU problem.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 06, 2011 | Acer TravelMate 292LMi Notebook
Display vanish 5 min after system starts. If we re-boot system does't boot.. if we remove the power cord for 10min & after that if we boot again System boots normally runs for about 10min & again...
first check if the cpu cooler has sufficient contact with the cpu as it may be a overheating problem.
second check if the capacitors are not leaking or bulged.
http://www.thenakedpc.com/dan/Bulging_Capacitors/
Dec 21, 2010 | ASUS K8N-VM Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
ON TURN ON THE FAN STARTS UP THEN SHUTS DOWN, DISC LED ON SOLID
This sounds like an overheat problem. Check that the cpu cooling fan is not clogged with dirt, if it is you can agitate the dust with an old dry paint brush and hoover it out carefully. Does everything else appear to run normally before it shuts down? Chris 07926-106150 http://www.motherboardsrus.net
Jun 08, 2009 | DFI CB61 Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
ASUS K8N-E Motherboard Logo
227 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
