Question about Toshiba e-Studio120 Copier
Flashing error code
My copier displays a flashing "H" then a flashing "4" error code. This error code appeared after area heater tripped the circuit breaker thereby interupting power to the e120. The e120 was on at the time but not in use.
    Novelist:
  • 208 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 20, 2007
2 Suggested Answers
  • 208 Answers
SOURCE: Toshiba e-studo120 H4 error code
This should do it.
What is trouble code 55pt6 on harley davidson 2011 fxdc
It's NOT an error code.
When you first go into diagnosis mode, the display shows "DIAG"
When you push the odometer reset button the display changes to "PSSPtb" (Not 55PT6...you're missing the flashing "P" in the front).
These are the different modules (sectors) that the display can show, with the flashing one being the one ready to show the error codes in THAT ONE SECTOR!
The correct procedure for displaying error codes is:
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" (this is what you are misreading as "55PT6", without accounting for the flashing "P") with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM (main computer "brain")
S = TSM/TSSM/HFSM (turn signal/security, etc)
SP = speedometer
t = tachometer
b = ABS codes (anti-lock brakes)
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's. Push the odometer reset button again to view any additional codes if they exist.
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part # of module will be displayed. This number IS NOT an error code!
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
12 - If the run/stop switch is in the "OFF" position, No RSP (no response) will display. Also in the modules (sectors) where there is no component to give a signal/reading (such as if you have no tach, No RSP will show in the tach sector. Same with the "b" sector if you do not have ABS brakes).
Aug 30, 2014 | 2010 Harley Davidson FXD Dyna Super Glide
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
How to test codes on harley
Press and hold the trip odometer reset switch while turning the IGN ON to enter diagnostic mode, release the trip odometer reset button and "diag" will appear on the odometer display. However if "no rsp" appears instead then you either do not have the RUN/STOP button in the ON position or if it appears after the PSSPtbhas appeared then the particular module that "no rsp" is displacing is not present on the motorcycle. THEN press and release the trip odometer reset button again and "PSSPtb" will appear on the odometer display, the letters "PSSPtb" refer to the different modules that could display codes if the motorcycle is equipped with those modules. "P" indicates ECM codes; "S" indicates TSM/TSSM/HFSM codes; 'SP" indicates Speedometer codes; "t" indicates Tachometer codes; and "b" indicates ABS codes. If you rapidly press and release the trip odometer reset button you can cycle through all of these letter(s) one by one and they will flash as you do so. Once a letter is flashing its corresponding module has been selected to show codes on the odometer display. When a letter is displayed and flashing if you press and hold the trip odometer reset button, if there are no stored DTC's"none" will appear on the display. If any DTCs are stored in the module, whether current or historic, they will be displayed on the odometer. If you the rapidly press and release the trip odometer reset button you can cycle through all of the stored DTCs. If "no rsp" is displayed move on to the next module and when you get to the last module the display will show "end". If you want to clear all DTCs for any module press and hold the trip odometer reset button and they will all be erased from the computer memory. If at the end of a display of DTCs you want to progress to the next step or sequence for that module, quickly pressing the odometer reset button will cause the module part number to be displayed. After that display if you again quickly press and release the trip odometer reset button the display will move on to the next module display in the sequence of modules. When you are finished and wish to exit the diagnostic mode simply switch off the ignition or run switch.
continue to the next module.
If you want to do a quick of instrument function, a "WOW" test can be performed by entering the odometer self-diagnostics. In this test the background lighting should illuminate, the gauge needles should sweep their full range of motion, and the indicator lights that are controlled by the serial data circuit (the battery, the security and the check engine) should illuminate. If the instrument fails "WOW" test, check for a poor battery condition or connections and/or a poor ground connection condition and check for proper ignition voltage to the instrument. If any feature in the speedometer or tachometer is non-functional, you will have to check further into that/those area(s).
Apr 20, 2014 | 2011 Harley Davidson FLHX Street Glide
Estudio3500 spanner flashing call service, how do you find what the error code is
When your copier is displaying an error the code will be found in the top right hand corner of the display. It will be a mixture of letters and numbers and will be 4 characters. If the copier is not displaying an error code, holding the c and 8 button will make it appear.
Sep 24, 2010 | Toshiba E-Studio 3511 Color Copier
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
H 4 flashing problem
H4 flashing on Sharp copiers indicates that the fuser tempurature has failed to reach temperature in a given time. The posible causes of this are 1.Failure of the heater lamp or heater lamp drive circuit. 2. Failure of the temperature sensing circuit. 3. The initial temp. of the fuser roller was very cold. or 4.low mians supply voltage for a short time (brown out). The copier does not allow a simple on/off reset of this fault because in cause 2. above the copier may overheat and cause a fire.
The reset for this model should be:
Clear ® Density select ® Clear ® Density select - 14-Print.
May 27, 2008 | Sharp AL-1642CS Copier
Sharp AR-5316
enter the following code.
cancel -- interupt -- zero -- interupt - the display should switch off then enter 14 and push the copy button- copier should reset if not heater lamp could be blown
May 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
This should do it.
Dec 20, 2007 | Toshiba e-Studio120 Copier
Flashing 4-H error message
try this reset procedure. Most likely this will work.
Nov 29, 2007 | Sharp AL 1631 Copier
fuser error - needs a tec - heater lamp, thermal fuse or thermister is broke. No simple fix
Oct 30, 2007 | Sharp AL 1631 Copier
264 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
