Question about HP 1020 Plain Paper Thermal transfer Fax
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in and print the same bit again then jam. Previously when this has happened, I have switched the mains off to completely re-set it, but all faxes have then been lost, but then faxes seem to come through and print without a problem. The only problem is, is loosing the faxes in the memory as there could be potential jobs sat waiting to be actioned. Please help!!! Thank you.
    Problem Solver:
  • 5 Answers
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Posted on May 26, 2010
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
Ran out of toner a week ago...stopped printing....did my print jobs and/or faxes go somewhere to retrieve later when toner replaced?
Your print jobs may still be in the spooler of the printer. Check the computer (Windows 7, Start > Devices and Printers. Windows XP, the title was Printers (IIRC)). The incoming faxes will be stored in memory; it can store up to 320 pages. (If you have other faxes in memory, the number of incoming faxes that can be stored will be less. Clear the memory after replacing the toner and printing the stored jobs. Press Menu until you see Maintenance then the left and right arrow to select the item to clear. Then press Enter to clear that area. When done, press Clear/Stop.)
I hope this helps.
May 17, 2010 | Ricoh AC205 All-In-One Laser Printer
Incoming faxes do not print, fax report reads 'power fail' and diplay reads 'low memory' - Can you help?
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
Dec 04, 2009 | HP Laserjet CM 1312NFI Color Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
Fax in receiving faxes but not printing them.
noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
Apr 16, 2009 | Canon FAX-JX200
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Incoming faxes from multiple locations jamming our machine
I believe there should be a "Clear memory", or "dump fax Memory", in the menu selection.
Press reports and scroll to machine print out. You should get a print out on the machines configuration and help menu to better assist you.
This should dump the memory so you can prepare yourself for new incoming faxex.
Dec 08, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP 1020 Plain Paper Thermal transfer Fax Logo
760 people viewed this question
Seeker5211
Seeker5211
