Question about Cell Phones
I used to Have 5 Bars on My Phone Now I Have only 1 Bar WHY? My IP Provider added more Towers and upgraded But My Phone downgraded. I am Not Happy.My Connection Speed Says I am Connected @230.4 But A Speed Check Shows 136 what Gives?
5 Suggested Answers
pingping
  • 111 Answers
SOURCE: V600
Probably your Antenna conection has some defect or may has some loosing part inside your phone. If you can open your phone by yourself, you can lloak at the antenna area to see any defect there. This one could be the defective part of the phone and need some professional tools to detect it. Please view the link below to see whether you can find any solution: http://www.howardforums.com/showthread.php?threadid=492770 http://repair4mobilephone.org/disassembly_motorola.html
Posted on Apr 11, 2007
Bajanguru
  • 7752 Answers
SOURCE: PROBLEM IN USB
best to have it reflash but i am not sure who will have that firmware for the chinese version N95
Posted on Aug 19, 2008
chanddra2009
  • 615 Answers
SOURCE: USING CELL PHONE CAUSE ITS BATTERY EMPTY VERY SOON
It is mainly due to Service Provider and Phone.When Mobile is low signal area it searches every second for regain the full Network so power consuming is more compare to mobile in Full Network Area.
Posted on Jul 08, 2009
SOURCE: LG CE110 (AT&T) shows 'Service Unavailable' with 5 bars.
I was trying to change security code and did not have a pin # and I changed my setting so no one could use my phone with code and it locked up and is asking for a puk code which I have no ideal what that is. I have no land line phone anymore,only my cell phone and I can't use my cell until it is unlocked. Please help
Posted on Mar 12, 2011
Getting signal
Unlocked refers to removing software that keeps a phon e"locked" to a specific service provider. Sounds like the phone you have is on a carrier that has poor coverage in your area. I would suggest contacting the provider of your phone to see if they can either 1) update the phones info so it can access other towers (for example - just because it is on Verizon doesn't Mena it is programmed to access all towers as towers are used by contract and towers are often updated) 2) provide you with a phone that is on a different carrier that has better coverage in your area.
Jul 14, 2016 | Cell Phones
If I remove SIM card from Motorola 376g. Cell phone will that bring my bars back
Roaming service towers cause interference or drops in call reception. Refer to phone service provider coverage map.
Mar 02, 2014 | Motorola Mobility W370 Cellular Phone
Motorola 376G cell phone has no towers
Valleys close to wireless towers usually cause call drops. Wireless carriers are always competing for coverage areas and improvements in reception. Switching carriers or buying prepaid emergency phones for dropped call areas is helpful.
Mar 02, 2014 | Motorola Mobility W376G
My EX124G cell phone receives a wireless signal from tracform of one bar then two bars.Then it goes back to one bar.At that time it drop any call I am making.Is the problem my cell phone or the wirless...
Your phone may be bouncing off of two or more towers due to location. You may need to contact the service provider to disable your phone from connecting from one or the other tower.
Aug 23, 2013 | Motorola Mobility Ex124g Prepaid Phone
My Nokia 6680 has a problem in detecting signal. it doesn't have a signal even 1 bar. I can't receive any call or text msgs. Sometimes, it has if there is "3G" at the buttom part of the signal...
i had this problem with my old phone with verizon. its because of where you are when this happens, the towers are too far away or their are too many trees in the way of the towers for your phone to get good signal. i got a bettter phone and went with AT&T and not had a problem since
Mar 05, 2011 | Cell Phones
When i make a call my strength bar decreases an drops the call
You might be on the border of two coverage areas, like the overlap between two towers.
First try powering your phone off then back on. Watch the strength meter for a minute or two then try your call.
It also might be dropping as you move it, or block the internal antenna with your hand. If you have speaker mode, hit that as soon as the call connects and watch the bars. They're not realtime, so you only see changes after several seconds or longer.
Try other sections of your house or car, wherever you're trying to use the phone when this happens.
Also, check your battery strength. If it's down to one or two bars, you should charge it up and see if that solves your problem.
Dec 18, 2010 | Nokia 6790 Surge Cell Phone
I got rly bad signal on my lg dare.but on my other cells the signal is very good.anyway i can boost the signal on my dare,or can maybe sumthing be loose inside the fone itself?
Yes, the same happened with my Nokia 3500. In order to use gprs you require quality signal on your phone but my Nokia 3500 never gave me signal more than 1 bar whereas it has 5 bars. I tried a lot with my service provider and Nokia help desk but to no avail then I removed the lamination from my mobile and there it is all 5 bars came. Then I thought what might be the problem. In my case the case came with 5 metalic links on the top side. which were like anteena and due to lamination they were unable to access the tower signal. You need to check out your phone for such anteenas. meanwhile I'll check your model with my friends. As LG will never give me hints through website or on internet.
Apr 18, 2010 | LG Dare VX9700 Cell Phone
Nortel IP soft phone 2050 shows the licensing failure
hello,
you can downgrade to an earlier version that doesn't require a liscense. you probably know that.Try upgrading to the latest (3.02.0045) version.
Hope this will help
Sep 22, 2009 | Nortel i2050
Sanyo pm 8200 sprint service no signal
Not sure about the bars, but you can go to the settings in the main menue and try to go to roam only. It could be that you r carrier is having a problem with their tower. Your phone, normally, will try to stay on your carriers towers. If you force it to a roaming status, you might get a better signal, but on a roaming network.
j
Jun 24, 2008 | Sanyo PM-8200
1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Mar 17, 2008 | Nortel 1140E
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
