Question about Ricoh Aficio MP 2000 Black and White Copier
How do I change paper tray settings? what is the code for 8.5 x 14?
  • adina_becerr Oct 01, 2009
    Well of course I would reference the Manual if we had one in the office. That is the reason I asked the question.
  • Ricoh Master
  • 1,294 Answers
Use the owners manual description,user tools .
Posted on Oct 01, 2009
We changed the paper type in tray 3 to high gloss and need to change it back to regular paper but we can't remember how.
Open and close the paper tray 3.The tray information screen will be displayed.Select CHANGE SETTING on the touch screen.You should now be able to change your setting.
Oct 20, 2011 | Xerox WorkCentre 7328 Multifunction laser...
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Jul 22, 2010 | Xerox WorkCentre M123 Copier
Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
Jul 06, 2009 | Panasonic Workio DP-1820E Copier
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Printing using various trays
Yes
Set tray (3? ) or other non standard paper type trays to type setting of letterhead and set normal paper tray (2) paper type to plain .
You do this on printer keyboad find menu then find paper handling, tray xxx, paper type. xxxx...set or tick
Via operations panel you can also printout current settings too to see if you have done the change if you do one before and after
Then test,
There are other settings on your printer that can effect this and driver configuation and doc type setting on pc that can effect this also but try step above first and report back if still having issues. Is it run by a server? Do you abity to change driver settings on your pc?
Oct 19, 2007 | HP LaserJet 4350 Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
130 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
