Question about Toshiba e-Studio120 Copier
Toshiba e-studo120 H4 error code
My copier displays a flashing "H" then a flashing "4" error code. This error code appeared after area heater tripped the circuit breaker thereby interupting power to the e120. The e120 was on at the time but not in use.
  • 2 more comments
  • aliced Jun 06, 2008
    i tried doing what has been aid in the fix it but it comes to the same thing ..error H4????????????and i cldnot find that botton 14 0r 1 that was said to press ...help ..alice
  • bps_daniel Sep 08, 2008
    can't find theAuto button
  • Anonymous Apr 13, 2009
    hello
    there is no auto button and no 10s button
  • Ben Oakes
    Ben Oakes Aug 13, 2018
    I need help in clearing error code 0xc0000185 , Toshiba studo120 error code, How to fix it??
    Novelist:
  • 208 Answers
This should do it.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 20, 2007
I did this.
1. Follow trikieone's directions. However the buttons need clarification.
-The Clear button is pink and is marked with a large "C".
-The auto button is not marked and is black. It is the third button to the left of the clear button on the control panel and has no markings.
-The 10 button is the down arrow under the counter led. Press this button only once.
-The 1 button is the up arrow under the counter led. You need to press this 4 times to get to 14.
Posted on Jun 21, 2010
    New Friend:
Is very good!
Posted on Nov 03, 2014
Error code H4
Toshiba studo120 H4 error code
May 06, 2015 | Toshiba e-Studio 161 Copier Copier
H4 CODE IN THOSHIBA
H4 indicates Heat roller low temperature detection. U need to check the themistor, heater lamp, themostat.
Jul 06, 2012 | Toshiba e-Studio 161 Copier Copier
The copier flashes an error code H4 and is in-operable. How do i solve this problem.
this is the heater unit error
very quickly in sequence do the following
[clear]-[exposure]-[clear]-[exposure] machinewill go dead input 14 and press start mc will clear error
if the unit is faulty you will have h4 again
Mar 17, 2011 | Toshiba e-Studio120 Copier
System error H4-00
Here is the text from a tip I have osted here on Fixya. It is for the Sharp AL Series copiers but your Toshiba is made by sharp and the reset procedure should be the same.
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Toshiba e-Studio162D Copier
The H4 error is related to the Fuser Unit not reaching the correct operating temperature in the correct time. You can try clearing this error with the following:
Make sure that the machine is switched on and the error is displayed. Enter the Service Mode by pressing the following keys # * Clr *
Enter 14 and press Start. Then power off the machine, wait 30 seconds and then power back on. The error should have cleared. If not then you will need to call in a service engineer.
Sep 24, 2009 | Toshiba e-Studio120 Copier
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Error code: H 4 flashes.. Nothing works
H4 PRESS START KEY THERE WILL BI A SUB CODE LIKE 00.THAT IS HEATER UNIT TEMPERATURE PROBLEM.RESET IT BY THIS PROCEDURE.
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
BY MIAN JEE
Oct 23, 2008 | Sharp Office Equipment & Supplies
Error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Jan 22, 2008 | Sharp AR-5320 Black and White Copier
Flashing error code
Dec 20, 2007 | Toshiba e-Studio120 Copier
Sharp Z-830
Nov 21, 2007 | Sharp AR-5316 Advanced Digital Imager...
2,279 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
