Question about Clarke Power Products Drills
Chuck has broken can i replace this and how much should this cost
  • richard_b859 Oct 03, 2009
    CHUCK NOT SCREWED ON THIS DRILL PRESS IS TAPERED
    President:
  • 1,489 Answers
Yes, a drill press chuck can be replaced. It screws onto the motor shaft. I would guess the cost to be around $20-30.
Charlie
Posted on Oct 01, 2009
Where Can I get a screen it is broken
Costs more money to replace to replace the screen than a new one costs... chuck it.
Apr 04, 2015 | Tablets & eReaders
It has broken chuck slot, need to be replaced
You can purchase replacement chucks from Hilti. 800-879-8000. Just put the end of the chuck in the palm of your hand. with your fingers pull the sleeve towards the palm of your hand. Then just pull the chuck off.
Aug 07, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
We have a chuck that got jammedand broken, is it possible to remove the chuck only and replace it or do u only get the whole front section with chuck. And if the chuck can be removed, how do u remove it....
With the chuck open as far as possible, look within the jaws of the chuck for a bolt or screw head that attaches the chuck to the shaft. Remove the bolt/screw and remove the chuck. Some chucks can also be screwed onto the shaft, so look for signs of threads at the base of the chuck. Otherwise, once the bolt/screw is removed, tap along the outside around the chuck with a plastic hammer to loosen the chuck. Penetrating oil will help.
Take your chuck with you to a "big box" type hardware store, where a replacement should be available. Any well stocked hardware store should be able to help you. I have found that the somewhat smaller hardware stores are usually staffed with knowledgeable persons, and getting a replacement ordered is easier. One is more likely to be stocked in the larger stores.
The name brand of the chuck isn't as important for a replacement as is the correct shaft size and style of fit.
Best regards, --W/D--
Jun 15, 2011 | Chicago Pneumatic RP9790 STANDARD GRIP...
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
Replace broken pull cord on RBC30SESA trimmer
The reason why ryobi tools are cheap is that when they go wrong and they all go wrong they should be chucked away as some times they can cost more to fix than buy new.
Depending on where you live you can contact roybi andthey have a very good service deppartment
Jul 23, 2010 | Ryobi 15" Electric Factory Reconditioned...
Chuck has broken how much is a new one
Depending on the size and manufacturer of the chuck a replacement should be between $35 and $50. You can replace it yourself by following the instructions on the new chuck. It's not very difficult and you can probably get the replacement at most Big-Box hardware outlets.
Mar 06, 2010 | McCulloch Md7d0010 - 18v Cordless Driver...
Bit is stuck. chuck wont open. turns but makes a
the chuck is broken inside if clicking. Ace and True Value stores sell chuck replacements
Mar 04, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Hi my drill chuck is stuck and will not retract, I think the bearings hve gone. How much will a chuck be to be replaced and repaired?
tricky question the size and the cost is important so .repair drill cost versus new drill?
new drill for me sir.
repair chuck may be good but other parts should be repaired once you are inside the drill which is going to cost more.
Aug 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drills Logo
Top Clarke Power Products Drills Experts
Are you a Clarke Power Products Drill Expert? Answer questions, earn points and help others
