Question about Garden
Just purchased a Poulan Pro Snow Thrower and on first start after assembly [new gas and 10W30 oil] the engine RPM has a rythemic surges about once a second. When a little choke is applied, the RPM becomes steady. If I have to bring it in to a Poulan Service Center, please provide a contact number for the Ottawa, Ontario [Canada] area. I understand that the carburator and governor are not adjustable. There is no correct product category for Snow Throwers so I selected Riding Mowers/Garden Tractors, but my product is a Poulan Pro Snow Thrower Model PP208E24 [96198002601]
I just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Posted on Nov 30, 2010
  • 279 Answers
The surge is common with the governor. Try the unit under load and see if it operates correctly. I think it will. Good luck...Lee
Posted on Oct 01, 2009
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Manual for Poulan Pro Pr300L
Check these guys out...
Have your model # and serial # handy...
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Mar 07, 2015 | Garden
Stalling
drain gas from carb and tank get some fresh non ethynol gas
while carb bowl is off spray/ clean with carb cleaner spray.
when you drain gas put it in clear container so you can see if there was water or dirt in it. helps to figure out the problem
Mar 27, 2014 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
I am unable to start poulan pro snow thrower. Recoil handle will not pull and electric start wont turn over. Brand new machine, never used. Is there a safty mechenism?
have you ever had it running?
you can check the starter, pulll it off and check gear at the end
if teeth are missing the you have to get them off the magnets on the flywheel. they jam it there giving the indications of a set up engine. I ve seen it 2 times
Dec 14, 2013 | Poulan Pro 27" Snow Blower Electric Start
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
I want to change the oil on my Yard Machines snow thrower with a 10hp Tecumseh engine and can't find the engine manual. What kind and how much oil should I use? Thanks - Zelmo
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
Dec 31, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Garden Logo
1,079 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
