Question about Refrigerators
Frozen Fridge Hi Hope you can help. I have a Candy Fridge Freezer (self defrosting). My fridge is completely frozen, even with the temperature set to 2 or 1 it's completely frozen everything in my fridge. Please advise. Thanks denise Dcefai03@yahoo.co.uk
  • 410 Answers
The temperature controlis most likely bad since you cant control it. the control is the knob you turn to set the temp with. you should be able to replace it yourself fairly easily.
Posted on Dec 21, 2007
Hi , i have a Z sidie by side maytag fridge/freezer my fridge section is freezing up even though the setting is now on 2.but the numbers are flickering,for both freezer and fridge compartments. l...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Maytag Refrigerators
Frozen fins and broken diffuser
assuming that you have not defrosted the unit completely,do so (ice is 0c..and you want freezer to be -18c)then let unit settle for 24hours,then check temp...
Apr 09, 2010 | Refrigerators
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Fridge is freezing stuff
try to call a technician the defrost system of Ur fridge might be damaged or u have a leak of gas on ur system.. tell him to check the thermostat.. also
Mar 09, 2009 | Candy CPCA270FFK Bottom Freezer...
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer works refrig part does not
You will probably have to completely defrost fridge, overnight. The air duct between the freezer and the fridge is probably frozen.
Jan 18, 2009 | Frigidaire FRS26R4A Side by Side...
Freezing food in my refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jan 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Candy CFC 290 FF
Candy frost free freezers have a 'self defrost' mechanism to remove excess ice build up. What happens is the ice gets packed around the heat exchanger in the back of the freezer and it can't self defrost. This is easy to fix but will require the fridge to be left switched off with the door open for a couple of days so all the ice can melt. Make sure you left the appliance off for as long as you can as if there is any ice left the problem will just come back.
Aug 30, 2008 | Candy CPCA270FFK Bottom Freezer...
GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Nov 01, 2007 | Refrigerators
Refrigerators Logo
467 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
