Question about Nokia 6500 Classic Cellular Phone
I have a nokia 6500 classic, can it be fixed?
I have a nokia 6500 classic, the sleep mode is on and it makes the screen go blank and I have to switch it off and on again to get back to a normal screen. When I did this last time, the screen now doesn't load at all and instead comes up black with coloured horizontal lines to the right of the screen. What's wrong with it and can it be fixed?
5 Suggested Answers
SOURCE: Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Posted on Oct 05, 2008
zohail
  • 1223 Answers
SOURCE: Screen gone blank
look first try reset the phone
pls first hard reset like this if it helps PLS RATE ME FIXYA for help !
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if it doesnt work then try this to hard reset
switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
pls let me know of the results and do raate me well if i helped u
if this doesnt work ur lcd flex cable or lcd itself might be damaged from impact or pressure u have to get it changed
Posted on May 17, 2009
devdeep dhar
  • 375 Answers
SOURCE: i have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Posted on Sep 21, 2009
jerseymark
  • 358 Answers
SOURCE: my nokia 6500 slide, has some problem with its
Hi, You will need to unscrew the phone and see if the phone screen is not broken, if the screen is not broken, that means the fllex of the phone is damaged and will need to be replaced.
The flex controls the displaying of the screen.
Posted on Oct 08, 2010
Unlock de restrict code for orange nokia 6500c
You can get the restriction code for a Nokia 6500 C from www.wickedunlock.com/nokia-6500-classic/rs11wp9/ at affordable cost. Here are the steps for unlocking a Nokia 6500C,
1 - Switch on your Nokia 6500 CLASSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 CLASSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 CLASSIC would then display the message "SIM Restriction Off" and will be unlocked!
Aug 05, 2012 | Nokia 6300 Cellular Phone
Unlock code
You can get the unlock code for a Nokia 6500 Classic from www.mobile-unlocker.com at affordable cost. Unlocking process is very simple and easier here.
Here are the steps for unlocking a Nokia 6500 Classic,
Jul 05, 2012 | Nokia 6500 Classic Cellular Phone
I have broken the screen on my Nokia 6500 and am trying to connect it to my PC to get the contacts and messages off - but I have to select PC suite mode in the phone and can't navigate because I can't see...
try download the nokia 6500 classic emulator: http://www.forum.nokia.com/info/sw.nokia.com/id/4d59d5d2-bec7-4a59-8d76-224b8dedf87a/S40_5th_Edition_SDK_1_0.zip.html
as your screen is broken you can use this emulator to see the exact keystroke to activate the bluetooth.
Anben Panglose
Mar 13, 2010 | Nokia 6500 Classic Cellular Phone
Nokia 6500 slide display 4900 problem
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Sep 16, 2009 | Nokia 6500 Slide Cellular Phone
No Sound after replacing screen
the ear peice is something you have removed to get then new screen in try making sure it is back properly it is easy to brake it moving it to put the screen in
Jun 10, 2009 | Nokia 6500 Classic Cellular Phone
My Nokia 6500 is not getting switched on
its problem flex if u change flex everything will be fine
or contact me balwinder_monica@hotmail.com
Jan 28, 2009 | Nokia 6500 Slide Cellular Phone
I have 6500 classic he off every 10 minutes w what i do
hi patrick sass, the best solution for that is take it to Club Nokia and make an update in softwre. that's the biggest problem of Nokia cell phones.
best regards
May 26, 2008 | Nokia 3110 Cellular Phone
Nokia 6500 Classic  Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
