Samsung DLP TV HL50A650 switches on and off
I have a Samsung DLP TV (Model HL50A650).
When I plug it in it switches on by itself and after about 5 seconds, shuts off. It keeps turning itself on and off until I unplug it. It made a burning smell when it first happened too. The LED lights which are supposed to diagnose the problem are doing what they normally do when the TV is switched on and off so they are not much help.
I live in the Caribbean and Samsung have been very unhelpful! Do you have any idea what the problem could be and whether someone (who is a competent electrician) could fix it without the help of a Samsung tech?
  • 1 more comment
  • lucyschofiel Oct 01, 2009
    I ordered it from the States and have it plugged into a 110V supply, with a surge protection adapter. I am not based in Europe, although that is what my e-mail suggests!
    When I have read other people with similar problems, they had to change the capacitor or mother board. Could this be the problem?
    So is this fairly easy to fix??
    I don't have the option of going to a Samsung tech to repair it, but we have competent electricians who know what they are doing.
    Sorry to ask so many questions, thank you very much for your time.
    That's not what I wanted to hear! Thanks for all your help though.
    Problem Solver:
  • 19 Answers
More than likely, the power level is too high for the TV. Make sure the votage switch on the back of the set matches what you are plugging into. For Example, in the US the set needs to be set to 110v, Europe is 220v. If you're getting a burning smell, it might be too late. That tells me that the amount of volts to the TV is greater than what the set is expecting.
Posted on Oct 01, 2009
  • 1 more comment
  • Mark Lee Oct 01, 2009
    yes this could be the problem, before I did that, I would throw a voltage tester on the wall and see what the voltage coming out of the wall is. The smell is either a capacitor, or a transformer that is getting too hot. Again, the issue is related to voltage, and the set is receiving more than what it wants.
    No worries about the questions, and no it's not an easy repair.
    Sorry. typically when a capacitor blows. Everythings stops. So I'm still leaning towards the voltage to the set. I'm not familiar with the voltage in the Caribean, so I'm not sure if it's 110. the other thing that would cause this would be not enough voltage. e.g. a brown out, depending on the sophistication of your surge protector, it would warn for a brown out condition. Fell the surface of the surge protector near the switch or where the cord comes out to plug into the wall. It shouldn't be warm at all. temperature indicates either an over or under voltage issue.
Samsung BP96-01653A Model HL50A650C1F I believe that the lamp went out on my Samsung 50 in DLP TV about a week ago. The TV would not turn on and the green lamp light blinks. I ordered a new lamp, fr
This sounds like a case where jumping to a incorrect conclusion has not resulted in the fix your were after. The problem could also be related to the power supply. Before going for another part it is best to consult a Technician who works on these all the time and get a correct direction to go before ordering a lot more parts. if you check on the internet with the symptom and model /brand of your unit- chances are someone else has already had this problem and may have the solution there for you to take advantage of. Of course each TV is different but it might be a better way to proceed than just guessing.
Aug 09, 2012 | Samsung HL50A650 50 in. TV
Ballast samsung dlp
Contact the nearest authorised service center for Samsung to buy an original ballast.
Jun 04, 2012 | Samsung HL50A650 50 in. TV
When I turn on the tv, the green light comes on for a few seconds then turns off. Why won't it turn on?!!! Samsung Model# HL50A650 50" DLP TV
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Dec 15, 2010 | Samsung HL50A650 50 in. TV
I have a HL50A650 DLP television. When powered on, no screen or sound. the fan kicks on only for a very brief period. 2 of the 3 led lights blink.
This sounds like a blown lamp,bad capacitor,bad fuse.You can open the panel where the bulb is and check to see if it is blown.make sure to unplug it first.if it is the bulb you will need to order a new one,make sure to dispose of the broken one properly these contain mercury.I hat the same problem with my 62 inch toshiba.The bulb was around 200 bucks new.
May 17, 2010 | Samsung HL50A650 50 in. TV
Samsung tv turns off on its own model hls4266wx
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Mar 12, 2010 | Samsung HLS4266 TV
    Why is my 42" dlp tv turns itself off after awhile?
    the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
    do it fast
    okay
    Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    Samsung dlp HL56A65 turns off and on by itself
    It looks power board problem.
    You need to get service from Samsung.
    Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
    TV turns off by itselft
    Feb 27, 2008 | Samsung HL-S6186W 61" HDTV
    Samsung DLP TV Powers Off by Itself
    yes i have the same problem i need help
    Aug 31, 2007 | Proton MM2701VT 27" TV
    Televison & Video Logo
    300 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
