Question about Dell 145W Power Supply SA145-3435 (SA1453435) Power Supply
Which wire is the 'ON-PS' switch for the Astec Model SA145-3435 power supply?
I found out that the AT supply SA145-3435 does not have a switch wire like an ATX supply. I have a SA145-3435 my self. To get it to work it must have a +5 volt load (BLACK and RED) and a +12 volt load (BLACK and YELLOW). If it does not have both of these loads it will power down after a 2 second delay when you plug it up. I used 2 small 12 volt bulbs. One for the 12 volt line and one for the 5 volt line. The type of blub I used was a #94 I got from the auto parts store.
Posted on Oct 18, 2009
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
Astec AA23080
You have to "short" two of the sockets.
Get the CORRECT two, or else you could kill yourself, or "fry" the power-supply.
Details: http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm about the "pin-out" arrangement.
It would be easier/safer to connect the sockets to a motherboard, and connect a power-switch to the ON/OFF pins on the motherboard, and then use that power-switch.
Feb 10, 2014 | Computers & Internet
Ref ASTEC power supply from old computer model SA 147-3505 I can pick up the logic 5 volts but not the +12 volts and -12 volts .FAN not energised so I guess there needs to be an elec link via the computer...
You can jumper on an ATX power supply by using a wire to connect pin 4 (green wire) to any of the grounds on the 20 pin ATX connector. The grounds are normally a black wire. You will need to put some sort of load on the power supply such as a hard drive to keep it running.
Feb 25, 2011 | Dell PWR,SUPPLY,145 WATTS,ASTEC SA150-3411...
Dear Sir, I have astec model AA23160 power supply input Ac 100-240 5A max output Dc +5v 23A, +12v 22A max it does not give output the LED give yellow when it is ON. the two cooling fans were also not...
Hi! l have have the same problem whit the Asctec model AA23160 power supply.But l need to know how many time your power supply worked: How many time do you use it?
Thank's!
Aug 13, 2010 | Astec 300w AT Power supply 190170-01...
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
Got a astec sa302-3505 power supply . . . need to know how do you add a switch to turn it on if its not connected to the motherboard
Simple, Just connect a switch to Green wire and one of black wire.
When the green wire got connected with negative (Black wires are negative) the SMPS Fan starts which is also a visual feedback to you that SMPS starts.
----------------------O /
Grean /
-----------------------O
Black
So simple..
Jan 26, 2010 | Astec 300w AT Power supply 190170-01...
I need an ASTEC power supply model SA147-3506 for IBM P-2 computer, Can anybody help me??!!
145 Watt power supply with the old style AT motherboard power cable connectors. (2 Each)
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
I just put Astec SA147-3506 in my browser search bar, and came up with a number of search hits. Prices ranged from $50 to $170!
And it's a 145 Watt power supply! Astec is a cheap quality power supply manufacturer, to boot!
You know, there is a way to use a newer reliable power supply, and the AT power supply motherboard connectors, off of the power supply you have.
It's not for the squeamish, but can be done.
The power wires are removed from the ATX power supply motherboard cable connector, of the new power supply, and inserted into the AT power supply connectors.
(ATX 12V power supply is the newer one. AT power wires removed from the P8, and P9 connectors of your old power supply)
Interested?
Jan 20, 2010 | Computers & Internet
I am looking for a manual and troubleshooting manual for a astec 73-180-0029 POWER SUPPLY
Look it up on the internet you should be able to find one. Try the www.astec.com website first.
Nov 19, 2009 | Astec Computers & Internet
Computers & Internet Logo
352 people viewed this question
Alun Cox
