Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Refrigerator is warm
Our freezer keeps frosting which is casuing the vents to ice. Therefore our refrigerator compartment is warm. if we disconnect the waterline will this problem be resolved?
  • Anonymous Aug 18, 2008
    refrigerator will not stay cold
  • 833 Answers
This sounds like a low gas issue....assuming that you are not keeping your door open excessively or that the gaskets are not bad or dirty. The water line probably has no part in this.
First, check the gaskets. They must be clean and seal well. Defrost the box completely. Leaving it off for 2 days will do this or use a hair dryer with care after removing the freezer panel. Clean the condenser. Turn the unit on while observing the compressor...the big black thing with the pipes coming out. Look at the largest pipe. It will start to frost up. If the frost clears either to water or dry after 5 minutes of operation, gas is okay. Still frosty...get a service man.
Posted on Dec 20, 2007
I have a whirlpool bootom freezer. The refrigerator portion keep getting warm while maintaining the temp level in the freezer remains constant.
It looks like you are getting frost/ice build up in the air vents( freezer is what cools your refrigerator side. If the ice blocks the flow up no air can travel to the other side). You removed the blockage by defrosting it but it will probably come back if the door does not seal properly. The only moisture you can introduce to the freezer is from outside...
Hope that helps
Jul 04, 2017 | Whirlpool Refrigerators
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Freezer vents full of frost.around every two months. Top refrigerator warm up. I resolve by removing all frost and ice from the freezer vents to clear cold path and get it to work. Possible problems...
First try melting the ice with hair dryer. See drain tube going to pan under frig? It can get clogged/frozen with ice. I cleaned mine with very warm water shot out of a water pik. Or u can hair dryer it, then pour warm water on the little pan that holds the drain tube. Be sure that tube is clear for draining.Otherwise, more ice at vents.
Aug 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Defrost not working heavy ice build up around coils
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Freezer developing frost and refrigerator not cold
check the circulation fan in the freezer compartment and make sure it is running.
Mar 13, 2010 | Refrigerators
Fridge compartment too cold.
Most bottom mount freezer units work by diverting some of the cold freezer air up to the refrigerator through a duct that vents to the top of the refrigerator A thermostat in the refrigerator closes a flap in the duct when the refrigerator is cold enough.
It seems like the thermostat or flap is not working in your refrigerator. You can troubleshoot this by turning the refrigerator to the full warm setting and turning the freezer knob in the cold direction until you hear the refrigerator turn on. Place your hand near the vent at the top of the refrigerator, if cold air comes out that means the flap is not closing like it should.
If the flap is not closing, it might be frosted open. Pop the plastic vent off (they are usually held in with snaps) and inspect the flap. It should open when the fridge knob is turned in the cold direction and close when it is turned in the warm direction. If there is no frost jamming the flap, and the flap is not moving, the thermostat is likely defective. See the pictures below, one is flap open and the other is flap closed.c0498df.jpg67c95ca.jpg
Dec 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
118 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
