Question about RIM BlackBerry Storm 9530 Smartphone
My touchscreen has stopped working. I have tried turning it off and removing the battery but it hasn't worked. It will not let me answer calls or access any menu buttons.
  • neillgordon Oct 01, 2009
    I have tried reloading the os twice now and this hasn't worked. The screen will scroll but not "confirm" things I click on. It now has the user agreement for the software on screen and will let me select the "OK" button as it lights up blue but wont accept it when I click down. This would suggest maybe a software problem?? As the screen itself seems to be working in some way therefore I think it is still connected .....please help this is driving me nuts!!!
  • 10,515 Answers
As you have already Tried Soft Reset. Go for Hard Rest. If that would not solve the problem, then it seems that the problem is likely hardware related. The next thing I would check is that the ribbon cable coming from the digitizer(touch screen) is actually still connected. To do this you'll have to open up the case. If it is and unplugging it and re-plugging it in doesn't resolve the problem, then I would say that the touch screen is bad or the controller is bad. If the touch screen is bad you can buy one new for around 50 - 100 dollars US.
Do a google search for " Blackberry storm 9530 touch screen " and the first few options would tell you the cost to replace it.
Keep in mind that if the controller is bad and not the touch screen, then this is a whole different story and you'll have to research the correct replacement part for your device. As far as I know, there is no easy way to determine which component is bad unless there is obvious physical damage.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2009
  • taran_2005
    taran_2005 Oct 01, 2009
    Thanks for your response!!
    This confirms a Hardware problem. I have seen, even if there is a problem with touch screen, you would not be able to select or use some functions. If this would had been a software glitch, you would be able to correct it when you did Soft Reset.
    Hope i helped you.
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
Samsung pl201 the zoom isn't working and stopping the camera from working normally. it says to take out the battery and try again. this hasn't worked.
Jul 17, 2011 | Samsung PL120 Digital Camera
Why has my phone stopped receiving incoming calls?
maybe it hasn't registered on the network for a while, try pulling the battery out with the phone on, remove the SIM card and then start it back up, once it is bcak on pull the battery again and start it up with the SIM card in again.
May 11, 2011 | HTC Cell Phones
Samsung TL240 touchscreen not working
remove the battery and memory card. blow out any dust. put back the battery in and turn it on without the memory card. see if you can take pictures, if so then its your memory card. Check the link below.
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=264556&PROD_SUB_ID=0&PROD_ID=1008&EMAIL_ID=
Jul 29, 2010 | Samsung TL240 Digital Camera
Touch screen not working
See the responses to this video.
http://www.youtube.com/watch?v=rst5yv2cc-w
One of the response to lift the screen with fingernails worked like magic for me.
Mar 25, 2009 | Samsung Instinct SPH-M800 Cell Phone Car...
Digtal answering machine not working.
I don't know yet if this is a resolution, but I'm going to try this tonight. Unplug all bases and remove all batteries from all handsets -- leave this overnight.
Here's the history of my problem. I rec'd this phone for my birthday. 3 weeks in, power went off in my building and answering machine part stopped working. I took it back to the store, and they gave me a new one. 4 weeks in, another power outage and I have the same problem. I called Panasonic, and they told me to unplug all bases and remove the batteries in the handsets for 'a few minutes' to reset the units. I waiting 10 minutes, and replaced all batteries and plugged in all the bases again. No luck, answering machine still did not work. I noticed, however that the phone did not reset as I still had all my phone numbers and caller id history.
I called my brother who is an electrician, and he advised me that the base has a 'capacitor(sp?)' and it will probably take a few hours for it to 'drain' so the phone will reset itself. His suggestion is to unplug all the bases, remove all the batteries and leave everything OVERNIGHT. By that time, the power store in the base should hopefully be wiped out and the phone should reset like new. I will try this tonight and let you know if this works.
Jan 31, 2009 | Panasonic KX-TG1033S Cordless Phone
Palm treo 755p not answering calls
Have you tried to restart your phone?
Jan 03, 2009 | Palm Treo 755p Smartphone
Iphone touchscreen not working
try fully charging the battery
Apr 15, 2008 | Apple iPhone Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
87 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
