When the 1055 runs out of paper from the roll it does not recognize a new roll of paper. It seems to try to sheet feed. We unplug the machine for two minutes, not just turn off, load the new roll and it "tricks" the machine into using the new roll. This is problematic because we loose everything in the print buffer and at times that can be quite a few drawings
I have contacted HP and there suggestion is to buy a new unit.
Oct 29, 2013 | HP DesignJet 1055 CM Plus Carriage Belt...
Jul 11, 2011 | HP DesignJet 1055cm plus InkJet Printer
Mar 04, 2011 | HP DesignJet 1055cm plus InkJet Printer
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
Feb 10, 2011 | HP DesignJet 1050c plus InkJet Printer
Mar 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Jan 01, 2010 | HP DesignJet 1055cm InkJet Printer
Oct 01, 2009 | HP DesignJet 1055cm InkJet Printer
Jul 31, 2009 | HP Office Equipment & Supplies
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
654 people viewed this question
When running prints from Roll 1 - the roll will slip to the right and cause a reload of paper roll.
